Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Refrigerator not cooling freezer is cooling but not as cold as normal refrig it is only 6 yearsold
  • mfk418 May 11, 2010
    posted about 4 times and I'm back It's about whirlpool side by side that neither freezer or fridge is cold. Cleaned the coils in front under grill also unplugged it for a few minutes was told by whirlpool to do that because it may reset itself, so far I see no change. Will it take awhile to get cold again, like I said before the freezer is blowing and vents aren't clogged with food in front thanks to anyone who can help
  • 136 Answers
Please check the following:
Posted on Feb 01, 2010
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
LFC20745SW- Refrign not working, the freezer working
the refrigerator is not defrosting automatically the vent is geting ice up blocking the air flow when you unplug it the refrigerator defrost and start working like normal they may be a problem with the motherboard
Sep 11, 2013 | Refrigerators
Refrig will not get cold freezer is fine, fan was sounding very loud last week but it stopped making the loud noise n the refrig seemed fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 25, 2011 | Samsung RF265AA Bottom Freezer French Door...
Refrig is not cooling. It is a GE Monogram. Freezer is at a normal ref rig temp.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | GE Refrigerators
Freezer ices up on normal setting, refrig warm
heatman101
Oct 25, 2010 | Amana ABB2224DES Stainless Steel Bottom...
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
155 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
