Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
I have a classixx 1200 machine and there is just one fill on the back. I have just moved and am confused as the pipe is red. I fixed it to the hot water supply but water is too hot. Should it actually be attached to cold water supply?
  • Bosch Master
  • 3,463 Answers
If there is just the one water inlet connection on the rear of the washer, then you must connect it to the cold suplly, as it is designed to work of cold fill only.
Please rate my solution to your question.
Thankyou.
Posted on Feb 01, 2010
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
My bosch classixx 1200, my washing machine leaks when not in use, to solve the problem i have had to have a valve fitted to the pipe that feeds water into the machine and keep switching the valve down to...
Remove top and check that they are your fill vaulves. Your hoses should be connected to them if so.If they are leaking on inside of machine when off then they need replacing.
Mar 15, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx 1200 wont start. Ready light is on, door is firmly shut, but start button does not do anything?
these things can be confusing! you may have it set on 'delayed start' or 'soak'- check the other indicator lights! 'soak' would fill and pause for a while, while 'soaking'- 'delayed-start' can be set for an 8 hr. delay on our fridgidair front-loader. don't know about the bosch!
check settings. if ready light is on, there doesn't seem to be a problem with door latch.
good luck!
Oct 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Conditioner not emptying in Bosch Classixx 1200 Washing Machine
ITS NOT THE DRAW THATS NEEDED CLEANING ITS THE JETS ABOVE IN ROOF OF DISPENSER THESE ARE DIFFICULT TO CLEAN UNLESS YOU USE HOT SOAPY WATER AND A SYRINGE TO FORCE THE BACTERIAL GROWTH BACK DOWN THE PIPES,IF YOU DO THIS KEEP GOING TILL NO MORE BLACK STUFF COMES OUT THEN TRY IT IT SHOULD WORK LEAVE THE DRAWER AJAR WHEN NOT IN USE THIS WILL CUT DOWN THE MILDEW GROWTH.
Sep 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch Washing Machines
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 6 1200 washer
Problem will be ... machine will use your hot water during the rinse cycles! So, No.
Aug 14, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
126 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
