My tv clicks when turned on,it has power, but no pic, or sound
My tv clicks when turned on but no pic, or sound
  • 644 Answers
You will have to remove the back cover, undo a couple of screws and gently prise the back cover off, once off, check the power board for a fuse, unpop it from the fuse holder and if you have or can get hold of a multimetre test it to see if it has continuity, if it dosent then that is your problem.
Also check the mother board for blown capacitors, these are barrel like in shape with silver tops, check for any brownish like liquid resadues on them or the board surounding the caps, also look for any capacitors with domed tops or slightly pretuding they should be completly flat at the top, if there are any they will need to be changed. if you need further assistance post back.
Posted on Feb 01, 2010
  • 1,476 Answers
Sounds like you need a new control board. www.partstore.com . Probably under $200 and fairly straight forward to install. Let me know how you make out.
hardrocko
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
61uwx10ba. no power to any boards but power supply.
have you reched around the new soldering area carefully, check for solder spills or drops in the printed circuit, also another thing to look for is some of those replacement stk do not hold their weight, you might want to take them out and try the old ones to see if you recover tv power.
Jan 15, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
No pic. no sound
Hi, the clicking is coming from a bad ballast that is unable to power up at this time. you will need to replace the ballast in this set.
Test the power supply board for any additional issue just to be safe.
May 23, 2009 | Mitsubishi VS-6041 60" Rear Projection...
If i turn off my tv it wont turn back on
This problem is either the TV's software or how the mainboard is distributing power so instead of just unplugging the TV, try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power/on-off button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Since hardware either works or it doesn't, your issue is either software or power related since you can get it to work so hopefully the power drain will indicate further.
Mar 25, 2009 | Proscan PS36109 36" TV
My 32in sdtv red power light,no pic no sound
hi there, this may seem like a sstandard problem, but differs from mfg. to mfg. in the sony tv's it is usually an open cap in the stand-by power supply, since you werent specific in your problem, there can be many solutions even for a single series or group of tv's even within the same mfg. give me specifics and i can answer more precise. hope this helps even a little.
Jun 12, 2008 | Televison & Video
your problem is likely to be in horizontal section of tv. please take the help of skilled tech. it is not a major problem but as you know that it is a high voltage device.
Oct 05, 2007 | RCA 32F531T 32" TV
Sony Trinitron Kv24Fv12
stand by timer light flashes 7 times no pic no sound. how do i
stop timer
Apr 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
