Question about Speed Queen Washing Machines
Please advise where the filter is located on our Speed Quen top loader washing machine, and procedure to clean filter-thanks
  • 619 Answers
Usually there is no filter to clean on the top loaders. It should be a self cleaning filter attached to the bottom of your spin basket, (what the clothes actually go into).
Posted on Feb 01, 2010
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Where do I find the filter on a Whirlpool top loader - our clothes regularly need re-washing as are covered in fluff?
have you check the outlet drain hose for blockage? go online check your wp model for built-in filter if any. if there is one you need the washmachine schematic show the location of the filter. most of the old machine may have a panel on the backside to access. this way you can get to the filter.
Mar 03, 2015 | Whirlpool 358276 Topload Washer Water
Does the top loader heavy duty machine have a filter and does it need to be cleaned regularly. If so, where is it located?
No filter to be cleaned in the machine. There are however small wire mesh filters in the screw on connectors that connects the water hoses to the machine at either the tap side or where it are connected to the machine inlets. Unscrew the hoses from the tap and machine inlets and check both hose ends if the wire filters are not to clog up over time resulting in slow water filling of the machine. Remove carefully and clean with a nylon brush. Replace again.
Aug 01, 2014 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Need to clean water filter so water will flo better
If it is a top load washer. No have! Front loads one are to the bottom left or right on the door side.
Jan 19, 2014 | Crosley Washing Machines
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
LINT LEFT OVER CLOTHES
It has a self cleaning lint filter. Front loaders call for "Special" HE detergent .....and I would only use about a table spoon..You may be Cloging the special self cleaning lint filter ,with extra soap .Top loaders use a lot of water compared to front loaders. Let me know ,If I could help Again! Thanks
Dec 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Aug 07, 2008 | Hotpoint First Edition FEW10P Front Load...
Our simpson 100 enviro won't drain. We think we need to clean the filter, but we can't remove the filter from the machine. How can we do this?
front loader filters are at the bottom use a screwdriver to remove it may be stuck full of coins.also make sure you dont have a button pressed in by mistake.hope this helps you
Mar 09, 2008 | Washing Machines
Washing Machines Logo
618 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
