Question about Dell 962 Photo All-In-One InkJet Printer
I can no longer print from desktop to printer. I followed all the tips and got nowhere but still communnication error box appears.
  • bogeyparbird Feb 01, 2010
    tried all that you suggested already, replaced usb cable, switched off firewall, used different port all with same result. Any other ideas?
  • bogeyparbird Feb 02, 2010
    unistall and re-install did the trick thx.
    President:
  • 2,923 Answers
Communication error? Meaning that the printer is not responding at all. Can the computer detect the printer when you connect it to the USB port of the computer? If yes, try connecting the printer into another USB ports of the computer.
You may also try to uninstall and re-install the printer driver. If same problem occur, install the printer to another computer or replace the USB cable.
If that did not help, refer to the user manual of the printer and see on how you can reset the printer.
Good luck and have a great day!
Posted on Feb 01, 2010
  • Melvin Ramos
    Melvin Ramos Feb 01, 2010
    The last thing that you may do is to upgrade the firmware of your printer and it should fix the problem.
    Unfortunately, I cannot advise you to download any firmware that you could download from the site because some of them contains malware. The best thing that you could do is to contact the manufacturer and let them guide you where you can download the firmware that you could flash to your printer. They know the version of firmware that would work best with your printer.
    If that didn't help, then the printer needs repair.
    Thank you!
Fsc5030n waste toner box
seems vey used maybe you have to bring it to a check
Apr 26, 2012 | Kyocera FS-C5030N Led Printer
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
I cannot get my document printed. when i try to print I get the message printer is busy then , another message that states a printing error occurred appears
Open Notepad and type the following lines:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save it in your root directory as: C:\DeletePrintJobs.cmd
Create a shortcut for it and move it to your Desktop
Now everytime you have print job(s) that got stuck in the print queue
go to your desktop and Double Click on the DeletePrintJobs.cmd
It will clear all pending print jobs in the print queue and allow you to
print new jobs again.
Jul 18, 2011 | Computers & Internet
900 Service RIP Softwrae on LexMark Optra T614.
any one of the boards in this printer can create this error it is a software communnications error. start with the easiest one the simm remove it power the unit on do this with each board untill you isolate which one is causing the error. cleaning the contacts sometimes fixes this problem. more times than not is a bad nvram chip on a board
Nov 23, 2009 | Lexmark Optra T614 Laser Printer
Turn on printer and light continues to flash. Not
What the flashing light means
The Power light can flash for several reasons:
• The printer cover is open.
• The printer is out of paper.
• A problem exists with the printer, such as a paper jam or a problem with a print cartridge.
If an error message appears
Read the error message that explains the problem and its solution.
If no error message appears
Check the status of the printer by using the printer tools. To gain access to the tools, open the Printer Properties dialog box, click the Services tab, and then click the Service this device button.
Use the printer tools to perform the following tasks:
• View estimated ink levels.
• Clean the print cartridges.
• Calibrate the printer.
• Print a test page.
• Perform other functions as needed.
Jul 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
Have a hp f380 all in one deskjet printer with M/S Vista OS
Ofcourse, if there is any software or patch, there will be free on the HP website. However, as you have mentioned, that you are able to print, that shows that the printing software is working fine, to test the scanning part, please confirm that you are able to make a copy or not from the front panel of the printer by placing a text document on the scanner bed, close the scanner lid and then press color copy. If you are able to make a copy fine, that shows that the printer functionality is working fine.
The issue could be with the communication or with the scanning software. To check the communication between the printer and the computer, perform the following steps on the Windows XP computer or Vista computer, be sure that the printer should be connected directly to the computer via USB cable at the back side of the tower without any USB HUB, as you are using a Deksjet F380, it is a USB connectivity printer.
XP:
Follow the below steps to Scan using WIA (Windows Image acquisition)
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Vista:
1. Press Windows logo and R on the keyboard*.
It will open a small run dialog box at the bottom left corner of the screen.
2. In the Run box type WIAACMGR and press enter.
3. Follow the onscreen insturctions and complete the scanning.
If you are able to scan fine using the above steps, then it shows that there is a communnication between the printer and the computer.
Please get back to me with the exact error message you are receiving when you try to scan from the computer, as to scan from the printer you should be able to scan fine from the computer (i.e., From HP Solution Center/ HP Director). So that I can assist you in much better way.
With Regards.
Mike.
Jul 03, 2009 | HP DeskJet F380 All-In-One Printer
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
ERROR MESSAGE
This error is usually caused by a bad formatter board.
But try the following:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Dec 13, 2008 | HP Hewlett Packard LaserJet P3005n Printer
HP 7210 OfficeJet - unnecesary cartridge messages
We had the same problem - after 2 1/2 years suddenly the dreaded dialog boxes appeared out of nowhere! We had tech support on the phone for at least 30 minutes to no avail. Finally we uninstalled and reinstalled the printer and all software and it disappeared.
Good Luck!
Apr 05, 2008 | HP Officejet 7210 All-In-One InkJet...
Apollo 2600 printer installed ok, but wont print
I don't believe Vista is compatible with Apollo any more. I know OS XP will work
Jan 30, 2008 | HP Apollo P2600U InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
