Blank monitor, flashing power light?
My monitor has gone blank. The light is green so it looks like it's getting power, but the light is flashing. What does this mean? Thanks! (I tried attaching it to another PC, but no luck.)
  • 1 more comment
  • lisasimpsonx Feb 01, 2010
    It is a flat screen monitor (digital)
    lcd
  • jimnuggats May 11, 2010
    What monitor do you have lcd or crt?
  • 644 Answers
Ok, so the the monitor is getting power, there could be a few faults for this problem, first the power board needs to be checked for bad capacitors, this will involve you opening the tv, at the back you see a few screws have a good route around though there could be screws hidding under stickers or have little black grommets covering them, once all the have been located and undone gently prise the back away from the front, its normally just plastic clips holding together now so be carful not to break them.
Considering thats gone well, and the back cover is removed, with the screen facing downwards on somthing soft ie a towel or somthing have a look on the pcb(circuit boards). The power board will be the one you connect the power to, so locate that board and have a good look at it. The componants that you are looking for are barrel like in shape with silver tops, if you see any brownish colour liquid resadue on them or on the board the cap is blown, also if the tops of the capacitors are domed or slightly pretruding they will also need to be changed, they are ment to flat at the top.
Second possibility is that the lcd back light could have blown therefore that could explain the black screen, these are harder to change and would be better to take it to your local appliance shop to get it repaired.
Finally the inverter may have failed, this is the board that scambles the signal from the computer into the picture you see on the screen, if this has gone then the monitor would power on properly but the screen would flicker or you would have a greyish tinge to the screen as though the monitor was on but no picture, out of these possibilities i think you can route out this problem because you have a flahing green light.
The first solution at the moment is the best option for a fix so try that first, post back what you find and will run you through how to change the capacitors if there are any that have blown. Make sure you check the tops of them thoroughly ensuring they are not domed or pretruded.Cheers.
Posted on Feb 01, 2010
  • 11,361 Answers
The problem can be bad caps in the power supply, or the power supply is sensing short circuits (in the inverter circuits) so it goes into shutdown mode. You need to open it up and look inside, repoart back what you see so we can guide you further, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
My monitor is blank. The power light is blinking ...
Throw it Away and buy a new one (its cheaper)....
May 14, 2010 | Computers & Internet
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
VL 1716 monitor. The display blanks out after 20-30 seconds. When I turn the power OFF anf Back ON, the display comes back normal, then blanks out agin after 20-30 seconds. The power light stays green.
This is due to system goes to stand by mode or Hibernate mode. To disable, go to power management and disable or incrase the time for the same.
Revert back for more assistance. Also give your valuable feedback/rating on the same.
Feb 08, 2010 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Blank Monitor
first trz another monitor, maybe is a videocard problem.
Jan 13, 2008 | Microsoft 1772-MS Repair Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Computers & Internet Logo
782 people viewed this question
David Payne
David Payne
