Question about Hitachi 43UWX10B 43" Rear Projection Television
My tv has no volume,i checked every cable connection and it all fine.I know my speakers are fine in the tv everything was fine until a button was pressed on one of the remotes the tv or the direct tv remote.i have checked all of my settings on the tv,shut down and restarted everything,and also unplugged evertything.I know it is a remote problem i just am at a loss what it could be? Can you give me some tips on what to do with the remotes???
Hit the LANG button on your remote....
Posted on Feb 07, 2013
My tv has no volume suddenly what could it be
Posted on Sep 06, 2010
  • 1,476 Answers
Remove all batteries from your remotes. Unplug the unit for several minutes. Plug unit in and use the controls on the set to turn it on and adjust the volume. This will eliminate the remotes. They could have a button stuck. If this does not work you may have a legitimate problem and need a tech.
hardrocko
Posted on Feb 01, 2010
After my girl tried to turn it on (God know what button the pressed) I can only hear a very low sound from the speakers, even when the volume is at max. speakers are connected properly, the input is in...
I wonder if she pressed the mute button as it is used to silence the speakers when required.. Look for a button with the sign that looks like a speaker with a cross onit
Aug 05, 2013 | Sony DAV-DZ100 System
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Volume increases to 30 can't turn down
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
Sep 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Headphones: only left speaker works
yes if you have a multimiter and a soler iron, just check the cable where is moving allot, for example for the headphones near the volume controler, near connector or near you eyers is more likely to brake
Aug 20, 2009 | Audio Players & Recorders
The built-in speakers on my laptop don't work but when i plug in external speakers, everything's fine. Do you know if this is a problem with settings or is the speaker blown?
This is a common problem, the cable that connects the button board to the system board goes bad. Usually but not always the power button stops working as well. Replacement cables can be purchased on eBay or from: www.2fix.net. Its fairly easy to replace the cables.
Aug 12, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
Buzzing speakers
It is merely degradation of the connection. Try unconnecting the speakers, cleaning the tips a bit, replacing them in, removing, recleaning, and then replacing a final time. This should get some scoring off of the connection... Aside from this, a new set of speaker wire is the best solution but just let me know what you decide on! Hope this helps!
Jul 26, 2007 | Sony MHC-ZX70DVD System
Hitachi 43UWX10B 43" Rear Projection Television Logo
346 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
