Question about Canon FAX-L1000 Plain Paper Laser
How to change time on canon fax l1000 - Canon FAX-L1000 Plain Paper Laser
2 Suggested Answers
SOURCE: Canon L100 fax machine
Just flip the little key cover open on the right hand side of the machine then press "Data Registration" then press "Set" then press "Set" again this will put you on time & date setting if you press "Set" a third time you can now change the settings using the arrows to step around and the numbers to change the settings. Just press "Set" when finished to save your setting & press "Stop" to exit programming mode.
Posted on Oct 21, 2009
Canon fax-l1000 super g3 - is it possible to operate this as a printer ? if so, is it possible to get a wireless adapter?
"canon fax-l1000 super g3 - is it possible to operate this as a printer ?" (sic) I have researched and NO you cannot do that.
The best you could do would be to Fax images.documents from your PC to this machine, that would effectively work, you would need a modem in the PC though, otherwise it will work fine... BUT not as a printer, as such. But you would still have the ability to store and manipulate the documents IN the Fax when received, and may just work, well, but with limitations?
You would simply have to dial the fax from the PC and send it to it, then it would receive,,store and print out as you wished... should/could work just as well as a wifi printer?
Aug 09, 2010 | Canon FAX-L1000 Plain Paper Laser
How do I change time and date please?
Press the dataregistration button.Select dataregistration.Scroll to usersettings press set.Scroll to date and time settings.Press the set button.Change the date and time and press set again.
Mar 02, 2010 | Canon FAX-L1000 Plain Paper Laser
FAX MACHINE CANON L100 ,RX ONLY BLACK PAPER?
Change toner,it may be damage.So you can change.
Dec 14, 2009 | Canon FAX-L1000 Plain Paper Laser
How do reset the time on Canon L100
Press Data Registration, select Timer settings, press set and you will see the time and calender. Enter each digit from left to right and then press set
Mar 26, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon-l100-fax
Under user mode (MENU), there must be something like user sett.
Feb 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Memory full
check the manual, you can bypass the memory by printing direct, or just print everything in memory hre is the link
http://www.retrevo.com/
Jul 31, 2008 | Canon FAX-L1000 Plain Paper Laser
Canon Fax L100 - How to set time
simple,
open cover that is used for one touch speed dial buttons on the control panel, press the button called data registration, then look for keys that go up,down, left and right and use them to scroll to to initial settings and press the set key to choose the date and time and set the correct date and time and press the set key to complete or choose that function and the up/down or left/right to make changes.
thank you,
mikey
Mar 30, 2008 | Canon FAX-L1000 Plain Paper Laser
Oct 30, 2007 | Canon FAX-L1000 Plain Paper Laser
Time and date
This looks like the UK version of the Canon 730. Look in the manual but as I recall, Press data registration and then set scroll down to time settings and press set and scroll down to time and date and set. Enter new time and date and set. Press stop to goto standby
Apr 26, 2007 | Canon FAX-L1000 Plain Paper Laser
Canon FAX-L1000 Plain Paper Laser Logo
49 people viewed this question
old marine
old marine
