Question about Kinyo Audio Players & Recorders
Kinyo Multimedia Speaker Model SW-80 Power Supply Missing
I have the Kinyo Multimedia Model SW-80 speaker system...I have recently moved and the power supply has been misplaced.
Could you advise as to the details of the required a/c adapter. What is the DC Volts Output and the mA Output
Thank you
Craig
SOURCE: speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Posted on Apr 04, 2008
Arius
  • 446 Answers
SOURCE: POWER SUPPLY
1.54 Amp
hope this solves your prob
part number for your Power Supply is 7000596 or 7000639
Posted on Aug 28, 2008
SOURCE: HK206 speaker power supply
this is power adapter specs for HK206 found elsewhere
Made by: HON-KWANG
Plug in class 2 transformer
Model No: D12-10-1000
P/N: 66-000-118-01
INPUT: 120V 60Hz 25W
OUTPUT: 12VDC 1000mA
The polarity is negative (-) on the outside and positive (+) on the inside.
I will try RadioShack for this...
Posted on Oct 21, 2008
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
SOURCE: Just wondering what the power supply output JBL Media 3 Speakers
I have JBL Media 3 Speakers running on the factory supplied power supply and the label states: JBL POWER SUPPLY, Model No. DV-9319B, Input: 120VAC 60Hz 35W, Output: 13.8VDC 1.7A, UL Listed3T58, E148325, CSA LR99152, Power Connection Diagram shows, Ring: Negative, Tip: Positive, CAUTION: INDOOR USE ONLY
PERSONAL NOTE: The power supply DOES NOT have the AC plug on the back. It is big hefty black block with an attached AC cord on one side and an attached DC cord on the other. My speakers are mounted high on the wall and run at approx.90% of full volume with Bass & Treble set flat. Actual volume and EQ settings are controlled via the sound card software based "Mixer Panel".
Posted on Apr 15, 2010
Channel multimedia speaker system
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fdocs.ts.fujitsu.com%2Fdl.aspx%3Fid%3D8515c87b-d9de-4b4f-8ab9-d60175717876&ei=LCVuU8WSBIiYyAT7_YBg&usg=AFQjCNGfuWC6xiGAcZr9Dsm0N3fMXPvSlw&sig2=mwq7IL9yo5Qym3p4ngqHJw&bvm=bv.66330100,d.aWw
May 03, 2014 | Fujitsu Siemens Computers & Internet
Kinyo ps-56 ac adapter
My kinyo ps-56 works in 7,5 v.
Hope helps
Apr 04, 2013 | Kinyo In Box 2 Ps-56 Multimedia Speaker...
Where can i get bose power supply distribution circuit?
I have a companion 5 . I bought it in UK hence 220 volt out needed . I move to Venezuela where Volt out let is 120 volt . It doesnot work due less power available . what can I do
Dec 26, 2012 | Bose Companion 5 Multimedia Speaker System...
Little to no sound from the left speaker. I've plugged a simular speaker in it's place, same result!
Check your computers volume mixer for a slide bar (balance) and set it to the middle.
Aug 29, 2011 | Kinyo SW-7352 Computer Speakers
Power cord not working that supplies power to the speakers
try to repair it or get it fix from a electrician...
better bpurchase new
Dec 11, 2010 | Kinyo 3-Piece Subwoofer Flat-Panel Speaker...
We use our projector for training purposes and the sound is not loud enough. Is there a speaker attachment that can be purchased for the x1a?
almost and desk top speaker system can be used, this includes the power supply for the speaker system needing to be used.
May 18, 2010 | InFocus X1A Multimedia Projector
I have lost the power cord and would like to know the replacement price
you dot necesarily need to buy a replacement, these power cords are universal and you should be able to use any other power chord from even a completely different device. PLEASE NOTE THAT THE VOLTAGE OF THE POWER CHORD MUST MATCH THE VOLTAGE OF THE SPEAKERS
Oct 08, 2009 | Kinyo SW-7352 Computer Speakers
Lost my power supply
Having some trouble finding any info online about them. Did they have a large power pack that plugged into the wall? If so, there might be some information either right around where they plugged in (im assuming on the sub) or possibly on the product info sticker on the speaker. Make sure if its a round plug in that you look for the tip information (whether if is a positive tip or negative). You might be better off buying a new set, depending on the price of a new adapter, compared to the price of a new set. Let me know if this helps.
May 11, 2009 | GE HO98015 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
136 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
