Question about SanDisk Sansa m230 MP3 Player
Turn every time i turn it on it says the title sceen over and over and over again whats up
  • Antlet Feb 20, 2008
    When I turn on my mp3 player it flashes "Sandisk initializing" and then it flashes "Sansa m230 512MB" and it just keeps going back and forth. When I plug it into my computer, it just flashes "Sandisk initializing" It was working fine a few minutes ago. Does anyone know what I can do?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 26, 2008
Netflix streaming
Try turning off and then on whatever device you use for Netflix.
Jul 30, 2013 | NetGear Computers & Internet
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
Sep 22, 2008 | Singer Quantum XL-1000 Computerized Sewing...
When I play my tape it split the sceen and 3/4 of
This all sounds like you may have digital effects turned on, check your camera meno settings and turn everything off and start again.
As for your sounds not being heard check your volume setting as it can go so low you wont hear.
Jun 11, 2010 | Canon ZR100 Mini DV Digital Camcorder
Plasma TV turns on and off after some time
get a sledge hammer and hit the damn thing
May 19, 2009 | Televison & Video
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
Jan 14, 2009 | Singer Quantum XL-1000 Computerized Sewing...
CHANGE CLOCK ON MY ALPINE CDE-9852
push title button til time comes up, then push and hold title button again til time flashes, when it does you can turn the dial til time you want comes up,then hit mode button below dail to switch to minutes , then repeat
Nov 10, 2008 | Alpine CDE-9852 CD Player
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Unable to set clock to the correct time
Can get the PDF of the manual on line and pg 8 tells you how. Basically you hit the title button till time is displayed. (Title button is on the right of the screen) Then hold the title button down until time blinks (hour blinks) to the dial and turn the dial and the hour will adjust. Then press the mode button (the one just below the dial) Then turn the dial again to fix the minutes.
Mar 24, 2008 | Alpine CDE-9852 CD Player
Sansa e250
You will need to do a firmware update format on the player.
Tech support at sandisk can send you the file you need via email, they do every day.
If you have the file, then put the player in recovery mode and drag the file to the 16MB icon in My Computer
Oct 19, 2007 | SanDisk Sansa e250 MP3 Player
Seeing green du42px12x
I don't have a solution, but have a similar problem, when sceens change, red and green pixels form and create a burn in effect from the privious sceen. It happens after the TV has been on for at least an hour. I notice it most when goinf from a light to dark sceen. Any help would be great
Dec 24, 2006 | LG 42PX5D 42 in. Plasma HDTV
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
