Question about Kenmore 73952 Gas Dryer
My kenmore dryer will not heat up and timer will not shut off on auto
    Scholar:
  • 91 Answers
`check ur restricted vent, or bad coils, is the vent is restricted the heat would built , but won't exit the machine, the gas valve shuts off, an wont come back on till it cools down then the same thing will happen over an over and that wont let the timmer advance an finish its cycle, take the backvent off an turn ur leaf blower an blow the lint off the duct, new houses with a roof vent specially here in chicago have problems when the lint an ice combine create a big vent problem. if you have a roof vent, u can remove the screen on the vent at the roof, birds will not go in,seeking for heat, because the new dryers dont have a stand by pilot like the old ones, so they don't provide heat 24/7, and when they inuse they blow so much air is impossible for a bird to stand the temp an the speed of the hot air
Posted on Feb 01, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Timer will run dryer but does not time
if the dryer has no heat the timer will not move on auto,when the heat shuts off the timer moves,when the heat comes on the timer stops,it will do this until clothes are dry
Oct 08, 2010 | Kenmore Dryers
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
No heat, timer not moving
Yes you need to replace the duct fuse and clear all air obstructions. I have repair photos HERE
Feb 17, 2010 | Kenmore 63942 Dryer
My kenmore 110.86273100 wont heat and the timer knob dosn't run down when running
if there is no heat the timer will not shut off in the auto dry seting. If a gas dryer possable bad thermo and fuse. Ele poss bad element
Dec 23, 2009 | Dryers
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
111 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
