Color Adjustment Only get blue and yellow
    Genius:
  • 3,587 Answers
Hmmm..blue and yellow on your monitor?
Posted on Feb 18, 2008
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Can't adjust the color
Sounds like a technician will have to determine if the blue CRT is failing or just needs to be adjusted.
Apr 23, 2007 | Hitachi 43GX01B 43" Rear Projection...
Computers & Internet Logo
93 people viewed this question
Alun Cox
David Payne
David Payne
