Question about Cooktops
I have a whirlpool RDE630CP1,and i don't know the color sequence,or wiring diagram to connect the infinite switches.
2 Suggested Answers
SOURCE: need to replace the infinite swithc
I've got the switch but i had to take off the bad one and take it to the parts store to get the replacement. Stupid me forgot to snap a photo of how the wires plug back in! Did you get your fixed and which wires are L1/L2 and which are H1/H2?
Posted on Feb 04, 2010
WhirlpooL gjc3634R502
Recheck the wiring to that switch you replaced, the light circuit was wired wrong, some switch have moved terminals on them so recheck them all.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 26, 2014 | Whirlpool Cooktops
Element on light on ... Nothing is on
This happens when one of the infinite switches short out. The indicator lamp will remain on even though none of the elements are heating up. To figure out which one is defective, gain access to the rear of the switches and remove the wire going to terminal P (Pilot) Restore power and see if the light is out now. Keep doing this to the remaining switches until you find the one where the light stays out with the wire removed after power is restored. Supply model number and we will supply the part number for the infinite switch. Be sure to let us know if it is the 6 or 8 inch burner switch. Good Luck and be careful. Eric
Mar 23, 2012 | Frigidaire Cooktops
Right front burner stays on high
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Feb 04, 2011 | Cooktops
How to change burner switch
If you have diagnosed a bad burner switch or infinite switch the hardest part is getting to it. The voltage is pretty high and you want to make sure the power is completely off to the unit before trying to fix it. When you get the the failed switch make sure your write down wire color and where it goes ex. L1, L2, H1, H2 and colors going to it. You can also just do a change wire for wire if you wish. Here is a link to the model number you provided to get an idea of how to get to the switch.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W1005127-00001.png
All the best of luck to you! Please rate me "4 thumbs" if I was helpful.
Dec 14, 2010 | Jenn-Air 31 in. Expressions CVEX4270...
One burner no longer adjusts temp when moved from 1 to High
Oct 02, 2010 | Jenn-Air JED8430 Electric Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Maytag cse9000ade cooktop. Does anyone have
Hi Greg. Welcome to FixYa. I am Kelly. I have been looking into this for several hours now. Even service manual(s). The only thing I can find is the yellow wire goes from the infinite switch to the right side elements. I don't see a blow on your model so the wiring diagram should be on the bottom of the pan cover. The bad news is I can not tell if it is actually on the bottom or inside the bottom. From everything I can see it appears that the yellow wire would be attached to L1 vs where you currently have it connected i.e neutral. I can not come up with the wiring diagram that is part of your cooktop but all of the other Electric Maytag and Jenn-Aire models show the same thing. Yellow wire from the infinite switch and L1. Take a look at your wiring diagram if you can find it and see if you come up with the same conclusion.
This became one of those solve the mystery questions for me and I literally have been looking at it for about 3 hours now. trying to get something I can safely pass to you that will not damage your unit.
With the yellow wire on neutral currently it would be operating on 110V and have low heat. Placing the yellow wire on L1 (Left) should get 208V to the right side burners. Again.. take a look at the schematic / wiring diagram that is attached to your unit.
This is the best I can do from here. The users manuals I have found for your cooktop are in several languages. ENGLISH is not one of them :(
Kelly
May 03, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
Need to replace the infinite swithc
Jul 06, 2009 | Jenn-Air 47 in. Pro-Style CCGP2820P Gas...
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Cooktops Logo
43 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
