Question about Canon Powershot SD450 / IXUS 55 Digital Camera
SD450 lcd went black
After about 2 years of use my SD450's screen went black. The camera is working fine otherwise. Pressinf "Display" button didn't help. Please advise.
  • Canon Master
  • 4,738 Answers
Please see the following post, and look for the SD400 LCD repair link. Click on the pictures of that site for larger pics. Follow the disassembly instructions, but skip the lengthy LCD removal portion. Instead just look for the LCD connector as shown on the front of the camera. Unseat the cable from the connector as shown by lifting the connector gate, BUT DO NOT unthread the cable through the camera. Merely examine its ends, and if it looks dirty gently clean it with a drop of alcohol on a Qtip. Give it some time to dry, and then reseat it back into its connector, close the connector gate, reassemble the camera and try it out.
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Make sure you also read the following Flash Capacitor Shock Warning post on the above blog site before proceeding.
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Good Luck and hope it works. If it doesn't the next step would be to check out the electrical wire power connection to the back light.
Posted on Feb 20, 2008
My view finder is screen is black..... when I take a picture, it shows the pic taken then goes back to a blank screen... it happened at a concert... it was fine then it went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 24, 2010 | Canon PowerShot A510 Digital Camera
Black screen; lens won't shut; totally not working now
Sound like the sensor or recoding electronics are bad. The camera is most likely beyond economical repair and I would buy a new one.
Nov 19, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
The LCD is black when I am taking fotos....otherwise it is working fine
Usually you would press the Display button to turn the LCD on, on with options, or off. I leave it off when taking pictures to save on battery life, though it does display each picture for several seconds after it is taken.
Jan 26, 2008 | Canon PowerShot S50 Digital Camera
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
Jul 22, 2007 | Nikon CoolPix S2 Digital Camera
Turns on, takes pictures, blank screen
I know in most digital cameras there is an option buried in one menus to turn display OFF. Perhaps, you can have a look around in the various menus to turn screen back on. Also, there should be another button or feature that allows you to view the shots you've taken.
Apr 29, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
My camera's LCD screen goes black every so often. What is wrong?
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 30, 2005 | Panasonic Lumix DMC-FX2 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
