Question about HTC Touch P3450 Smartphone
My htc touch phone don't want to charge i put in the chager and the light just blinks. what seems to be the problem.?
    Guru:
  • 170 Answers
Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well enough. It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
WARNING:
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
WARNING:
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 30 seconds. Then quickly plug the battery back into the mobile, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 30 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Posted on Feb 01, 2010
Orange light blinking mean
just because it works on another phone doesnt mean its not the charger.
Mar 27, 2014 | HTC Cell Phones
My HTC touch diamond - wont start, if connected to the charger it only makes "click" noise ..lights for 1 second, then it "dies" again :(
I have this kind of problem =( . i have htc touch diamond and when i charge the phone it has 20 % batterylife , the phone is lighting BUT after 6 h i look at the battery life after charging and it has still 20% of 100 % battery life
so it has the chargin light but the battery Wont charge =(
Oct 30, 2010 | HTC Touch Diamond Smartphone
What does blinking orange light on the phone mean?
Solid amber light when the battery is being charged.
Flashing amber light when the remaining battery level reaches below 10% htc has had some problems with batteries,when charging, if you are getting the flashing amber light feel the back of the phone. if it is feeling hot you may have a bad battery. hope this helps.
Jan 23, 2010 | HTC Touch Cruise Smartphone
Htc herm200 can't charge
Hold down the two soft-keys (the ones below the screen) and while you have them held down you poke the reset button with your stylus. You'll then see a message on the screen saying 'press R to reset, X to exit'. Pressing the R key on the keyboard will hard-reset the device. It'll now take a few minutes to reboot and load all of the operator customisation etc.
This procedure will hard reset the HTC TyTN, Vodofone v1605 and all other HTC Hermes variants.
Dec 17, 2009 | HTC TYTN GSM Phone
My htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Sep 25, 2009 | HTC Touch Pro Smartphone
HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
Jul 12, 2009 | HTC Touch Viva Cell Phone
Htc p 3300
dismiss all messages/notifications (for NO Blinking amber light), disable vibrate
attach the original charger, keep phone on a flat surface, find optimum position where the amber light is continuous.
repeat same if you answer any calls or move the phone
May 14, 2009 | HTC P3300 Smartphone
Micro sd memory not recognizing with the htc touch
the micro sd reader inbuilt in ur phone has burned off
Jan 08, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch P3450 Smartphone Logo
171 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
