I have a gateway w/ vista home premium. After i hit the power button to turn it on, the machine goes thru the regular process of booting and before it gets to the login screen a black screen apears. At this screen there is a cursor, most solutions (been looking about 3 hrs now) say to either use a disk to repair or reinstall window or use the taskmanager (ctrl+alt+del) i have neither ctr+shift+del also does nothing
  • Hank May 11, 2010
    Hi, I can't offer a solution because I don't have Vista, but check out this link:http://forums.techarena.in/windows-vista...
  • 30 Answers
You can try to press F8 after you first turn on the machine, you want to keep tapping it but not super fast or you can make a keyboard error. Just until a screen appears that will give you the option to boot in Safe Mode.
If you can boot in safe mode you may be able to also choose "Last Known Configuration that Worked" as an option.
This is about the 5th option down on the screen (NOT in VISTA SAFE MODE)
If none of these options work you will just need a Vista Disc. If you use this it will not detroy your data unless you delete the partition.
But you will lose your programs, or at least have to reinstall them.
**IMPORTANT**
You must have a regular VISTA DISC not the ones that come bundled with computers. Those will 9 out 10 times erase everything. and are meant for specific machines. Plus the usually install quite a bit of bloatware on your PC.
Posted on Feb 04, 2010
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
Acer desktop PC locked up and now won't turn off or boot up
I've seen a similar issue on Acer Veriton 7900. When you unplug the power chord while the machine is still running the BIOS/CMOS gets bugged up. If your PC doesn't have a 3 year warranty you can clear the CMOS/BIOS. To do this, note the following...
1.) Unplug the power cord
2.) Remove the CMOS battery from the unit
[OPTIONAL] move the jumper on the mainboard to the 'clear position' It should be indicated on your mainboard.After 30 seconds move jumper back on original position
3.) Wait for 30 seconds
4.) Place CMOS battery back into its position
5.) Reconnect the power cord and attempt to power on the unit.
May 13, 2010 | Acer Computers & Internet
I have oem vista home premium and need to format
most computer makers put the restore on a partition of the hard drive that is accessed using an F-key on bootup. You should see f-key options displayed (very quickly) on booting up and one will be "restore". For example, on an HP machine, it'll be F11 you hit on boot up to go into the restore partiton.
Feb 07, 2010 | Microsoft Windows Vista Home Premium with...
Gateway/vista black screen with no ctrl+alt+del but a nice cursor
Try this, before it boots up and just after in posts press F8, it should bring up a page where you can choose your boot option, choose "Safe Mode", if the computer does boot to safe mode there are a few steps you can do to remedy this.
First goto my computer, c:drive/windows and scroll down to a folder called prefetch open the folder, highlight everything in that folder by left clicking once on one of the icons and holding control(ctrl) then pressing A once everything is highlighted hold down the shift key and press delete, everything should now be gone, exit out of all the windows do a disk clean up, my computer right click on c:drive (your main drive) and click on disk cleanup tick all boxes and then click ok to start deleting the temp files. once finished reboot mechines and leave it to boot up. if you still are having problems or it wont boot up into safe mode post back. cheers.
Feb 01, 2010 | Computers & Internet
Laptop cursor jumps around, turns crosshair, screeturns black
windows vista is probably the problem...have you tried running a virus scan? McCaffe...could actually have one from the factory
Oct 05, 2009 | Acer NSK8458AN Keyboard
Gateway laptop modle mx8711 windows failed to load
Try to start in safe mode and then when it finished loading shut it down again. Boot again it should boot to windows if it not, maybe a corrupted files or some files are missing.
Apr 01, 2009 | Microsoft Windows? Vista Home Premium...
Boot Problem
Your Hard Drive is getting weak replace it with a new one , sometimes when it gets weak and get bad sectors it does not take up the OS and Boot bcoz the data written get lost so replace it or do the double check as follows
check ur hard drive is it showing u in Bios the main culprit is ur Hard Drive try re loading ur operating system by formatting ur hard drive otherwise Change ur Hard Drive it has become weak , there is a hard drive checking utility like HDDLIFE try connecting it to another desktop and scna it thru this software see the strength of the hard drive ur self download the trial version from website www.binarysense.com and let me know if it helps ,
basically if u computer boots ok and goes in bios when u press key that seems like ur whole pc is working ok incl RAM the only thing that is responsible for the operating sys is Hard disk it is where all files reside so when it crashes or get weak it doesnt give up files to boot so pc is unable to boot forward
pls do vote me if u find me helping and fixya problem
Feb 23, 2009 | Gateway 310 S PC Desktop
I/O error. HP 1720n won't boot
Run diagnostics on the hard drive (Normally provided either in the F8 or F12 boot menus) and se if you get a failure.
If the drive passes diagnostics, boot to the Vista DVD and run the repair option. (Note: you may have to the Vista repair process 4 or 5 times if there are multiple errors to be resolved)
Sep 13, 2008 | HP Pavilion a1720n PC Desktop
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
