Canon laserjet is ghosting when printing in colour
My canon laserjet is ghosting when i print in colour all lines are off sync but ok when I print in b/w - why as had the machine for a while and been ok up til now.
Why is there ghost printing/shadows on my xerox workcentre 7335?
Suresh,
You don't say if the ghost is a particular colour, by ghost I suspect you mean similar to a drop shadow.
Firstly run off an internal test print, one of each colour if the grid lines are fine and showing no signs of shadow then your problem is not an internal problem. Don't send a C,M,Y,K test print from your computer, you can't eliminate colours that way.
If you can pin the problem down to one colour it could be a particular drum unit. Investigate from there.
Good Luck.
May 03, 2015 | Xerox Workcentre 7335 All-in-one Laser...
Pink lines when I print on proper Canon photo paper
i'd say your print engine is quite out of sync...you had this canon for a while?
Mar 18, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
Canon i550 not printing any color, Prints in black OK but no color.
Please check nozzle head pattern first. Is your print head pattern printed perfectly?. Be sure that the print head pattern is ok. No missing line or column. If your nozzle colour is not printed at all even just one point,check the print head or try to clean the print head.
e-manualshop
PrinterClinic
Jan 03, 2010 | Canon i850 InkJet Photo Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same timeannabellamt
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal16
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
Colour printing coming out with lines throughout print - shading
my color prints have proper colors but lines come through all through the print even using the best canon photo paper
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
74 people viewed this question
jasbo
jasbo
