Question about Electronics - Others
MICROSOFT 1G MINI SD SAMSUNG WILL NOT FORMAT - Electronics - Others
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 03, 2010
I want to move all my data on a Samsung Galaxy Trend Neo on a SD card. I have a new phone and want to give this phone to some one else without any reference to me
They make a adapter that looks like a camera SD card, and you put you mini SD card inside of it and then you can put all your information on your computer and put the new mini in the adapter and cut or copy it to you new SD card. don't forget to format your old one before giving it to someone.... I always format a new one before I put anything on it also.
Hope this helps.
Apr 02, 2017 | Samsung Cell Phones
I cannot format my brand new SD card with my Canon Powershot 970 IS. It is a 4G, however i just tried an old 1G and it will not format that one either .... perplexed.
Try another type of SD card as the Canon camera are very choosy with regards to SD card. All I want to say that, not all SD card will work on Canon camera. Or if you insist of using your SD card you have to format it in your computer using Canon formatting software which is downloadable in the website.
Mar 09, 2011 | Canon PowerShot SD790 IS Digital Camera
Bought 4gb memory card for dx6490 but it wont format..is there a way to make it work
The DX6490 is only compatible with SD/MMC up to 1G.
It is not compatible with SD/SDHC Cards.
Pls. use the recommended SD card and the problem should be solved.
Dec 14, 2009 | Kodak EasyShare DX6490 Digital Camera
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
How do I format the mini sd card for my at&T LG Xenon Gx500
You can format your sd card through card reader to attach the computer by format command or you can also format the card through format command in dos.
C:\> format :drive name
Sep 23, 2009 | LG Xenon GR500 Cell Phone
How to format a SD memory card for samsung
Hi Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Sep 09, 2009 | Samsung SC-X210L Mini DV Digital Camcorder
    Sd card format
    Acording to motorola, The SLVR L7 is limited to a 1G micro SD card. Anything over this will not be usable in this phone.
    Dec 27, 2008 | Motorola Mobility SLVR L7 Cellular Phone
    Reformating a micro sd card
    i would like to know how are you formating the phone
    is it through the blue tooth
    or by optical fiber cable connection.
    Jan 03, 2008 | Samsung SGH-E900 Cellular Phone
    Electronics - Others Logo
    64 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
