Question about Car Audio & Video
Amp buzzing in range rover
My car stereo is buzzing whether its switched on or not> tv, sat nav and radio work fine but the buzzing is constant as soon as you turn on the ignition. I think it is the left speakers only but not sure
    Problem Solver:
  • 4 Answers
Have you had any electrical work done to it recently?
... try two things.
One, unplug the RCA cables from the amps to see if it is with the signal or with the amp itself.
Two, check the ground connections for them to be nice and clean as this may cause this issue.
If the buzz stops when unpluggin the RCA cables.. it's either a problem with the cables or with the Head unit sending this weird signal. (NOTE, if ALL speakers have the buzz it's mostly caused by the HU, thus, if it is only with one side as you explained, I'll lean towards a bad cable, or an amp failure (either not receiving proper ground, or it has gone bad.).
Hope this helps you some. if not, lemme know and I'll try to help you thoroughly.
Fred
Posted on Feb 19, 2008
Range rover sat nav fails to come on
There may be a problem with the function switch.
May 05, 2014 | 2003 Land Rover Range Rover
2001 BMW X5 radio works intermittently
Most sat nav/radio issues are caused by a flat battery! The most simple solution to try is th switch the vehicle off, go to the fuse box on the right hand panel of the boot (as your facing boot) remove fuse 24 (5 amp) for 5 minutes then replace and start vehicle as normal! This will reset the nav/stereo system! Rich B
Apr 07, 2012 | 2005 BMW X5
I purchased a 2002 Range Rover Borrego recently.
I have experienced many electical demons with all my British cars. The nav units can and do fail. I had a goofy one this summer and the only way it got fixed was to replace it. The module not the head unit
Mar 24, 2010 | 2002 Land Rover Range Rover
Sat Nav. Vehicle position on screen wonders off after 30 mins and screen shows 'no signal'dealer says no fault found! can you help? what receives the signal?
did you check how many Sats ur Navi found??? if it found only 1 then it could be it  usually for perfect work it needs 3 and more Sats
Jan 29, 2010 | 2006 Land Rover Range Rover Sport
L322 reg02 radio display not workin no sound on tv or sat nav. visual display working on sat nav and tv but no sound. seems as if there is no power to left hand side of unit. righthand buttons working but...
solved the problem after speaking to the main dealers, disconnected battery for fifteen minutes then reconnected which rebooted system. Range rover say just like your home computer its got glitches so rebooting works, common problem in cold weather.
Jan 13, 2010 | Car Audio & Video
I put 3 music cd's in the sat nav!!
go back to dealership truck should still be under warrenty
Dec 29, 2008 | 2004 Land Rover Range Rover
X5 dead satnav/radio display
I had the same problem with the suspension on an o2 X5 Sport,it was the stabiliser pump in the rear,Range rover is the same pump and is cheaper than the BMW part,they also do an exchange unit.
Jun 24, 2008 | 2005 BMW X5
Bmw stereo
check the main brain plugs are plugged in behind the left hand side rear boots carpet panel your will see a couple of brain boxes there for your sat navs dvd and the main brain for the radio , there also known for getting corroded connections because the brains are in the boot .
check that anyway first .
Dec 29, 2007 | Car Audio & Video
Car Audio & Video Logo
175 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
