Track Eraser Deluxe
I have Track Eraser Deluxe free down load on my pc. It doesn't show up in the start menu items, nor does it show on my control panel. It only shows in my tray in the right hand corner at the bottom of my desk top. I can't uninstall it from my pc and there is no option for uninstalling when I bring up the info it provides. Went to the site and no info. What can I do?
  • 644 Answers
Goto control panel, click on clasic veiw on the left hand side of the window, double click on programs and features or add/remove programs depending on what operating system your are using, find the program you want to unistall, just right click on the progam and the options for that program should show up, click on the option desired.
Posted on Feb 01, 2010
  • jimnuggats Feb 01, 2010
    If that dosent unistall the program, the only other way is to delete it manually, goto my computer, c:drive, program files and look for the program folder you want to delete, it maybe under a diiferent name so you will have to check the softwares vender name as well, once you have found the folder try and delete it, if says it cant because it is being used you will have to stop the application using task manager and then try to delete it again. post back what happens cheers.
    The program you have downloaded is a explorer add-on, to disable it you will have to goto tools and the manage add-ons, left click on track eraser deluxe and click on the disable tab in the bottem left hand corner.
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
Tip
How to Decrease Menu Show Delay Time in Windows Operating Systems.
Go to Start--> Run and type "regedit" without quotes, Then Registry Editor will open, Navigate to HKEY_CURRENT_USER--->Control Panel---> Desktop. Look to right pane and search for "MenuShowDelay", Change the value (default=400) by modifying it to "10". Then restart your computer and you can find the Start Menu items accessible very fast.
on Dec 07, 2009 | Computers & Internet
How can I do to show on the screen the activation of the caps lock key?
You can "hide" or "show" it from the notification area via:
Start > Settings > TaskBar & Start Menu > place a check next to "Hide inactive Icons", then click Customize, Located the items and you will see a drop down menu appear. Select "always hide" or "always show" and click OK > OK.
Mar 30, 2013 | Computers & Internet
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
My icon for the battery power monitor has dissapeared from my taskbar can you help me get it back please
Do you have Windows 7? If so, you can right-click on the bottom right corner of your desktop (try right-clicking the time/date), where the icons for volume control, wireless, battery, etc... should be and select Properties. You should then see a screen where you can turn on/off the icons/notifications for battery power (sometimes my volume control disappears and i have to do this.
Otherwise you can go here, Control Panel\All Control Panel Items\Notification Area Icons and you should find the same thing. Then just turn on your battery power icon/notifications.
Hope this helps.
May 22, 2011 | Acer Computers & Internet
How to locate "my computer"
To put the MY COMPUTER icon on the desktop, click the START button and right click on COMPUTER. Click the "SHOW ON DESKTOP" item in the menu and your COMPUTER icon will show up on your desktop . . Easy, yes?
Nov 23, 2010 | Computers & Internet
I have not used my ibm2681 in 2 years and it needs an unlock code on startup. i bought this thing from my nephew 3 years ago and he cant remember anything . please help
Ok try this, it should work so long as the Administrators password is blank. which it is about 90% of the time
Start the computer, as soon as you see the manufacturer logo on the screen start hitting f8 series of smaller keys at the top op your keyboard.
Once that happens, you will see a menu that allows you to load in safe mode. load in safe mode and don't get scared but you will see a whole mess of items come across your screen.
then when windows finally starts up, click the start menu, then click control panel, under control panel you will see users accounts, click the account thats locked and there will be a small link that says remove password. and then that account wont have a password and you can log right in.
If the admin account does have a password, then your up a creek a lil, but there are still other solutions this one is just free..
Thanks for using FixYa.com please remember to leave 4 thumbs
Oct 07, 2010 | Computers & Internet
Ive lost the graphic that shows voice recording how do I get it back so I can edit the track
Go into the control panel of your software .. which you should be able to see by opening it ...then make sure that in your microsoft control panel ( off your start ) go into sound devices and make sure the settings are correct there .
Jul 12, 2009 | Magix Music Studio 11 deluxe for PC
The bios is not installed
Go to BIOS, under Advanced > PCI Configuration. Disable Onboard ATA device if you're not using RAID. Also, make sure under Boot Menu that Other boot device do not show SCSI/Onboard ATA.
Hope that helps.
Mar 02, 2009 | ASUS P4P800-E Deluxe Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
