Question about Nokia E71 Smartphone
There is no volume in my audio and ringing tune
Why does my bt cordless handset not ring
Have you set it to silent by accident ? Check ringer volume and also check you've set a ring tune too.
Oct 02, 2016 | BT Lands Phones
I have a constant ringing sound coming from the tv. It goes up and down as I increase or lower the volume by remote. As I change the audio option to "Spanish", regular "English" audio comes out on c
The fact it shows on tuner and not DVD means not likely a audio problem--check all audio settings in the set's menu AND if you are using a box for signal look there--has to be a setting.
Some JVC sets (brand indicated here) also had issues with when watching the background audio (like a sporting event) was louder than the people talking and could be interpreted as ringing--This is a setting in the set called something like "Theater" or "Hall"
Has to almost certainly be a setting in the set.
Mar 28, 2012 | JVC Televison & Video
When the truck is turned on the speakers make a boom sound then they buzz??
is this afetermarket stereo if so check you ground on the amps
Feb 09, 2011 | Car Audio & Video
My nokia cannot ring.the speaker is o.k and when i go to ring tune,it goes off.pls hlp.
1. Try to make sure it is not on vibrate or silent.(usually indicated by an icon of a shaking phone at the top right of the screen) It can usually be turned on and off by holding down the star button.
2. Make sure you have your volume up.
3. Change your profile. Usually there are different profiles on phones for different places, i.e outdoor, silent, vibrate, etc... It can probably be found in the settings under something like audio, ringtones, profiles, etc.
4. The phone may just be deffective. I would suggest if after trying the above it doesnt work, to contact either your phones manufacturer or your cellular service provider. They may be able to help.
Jul 30, 2010 | Cell Phones
Hello, I have a Nortel 1140e with SIP firmware that has been configured to work with my home VOIP system. The basic features work, but the phone doesn't ring on incoming calls and there's an audio delay...
First I will suggest you to upgrade the Firmware....check the ringer tune and volume is OK ... or try pressing Feature key * 6 and Press 1,2,3,4 or next to hear different type of ring types .....Press OK to save it....Now Try....Further result please let us know...Thanks for being with Fixya....Good Luckmoz-screenshot-1.pngmoz-screenshot.png
Nov 08, 2009 | Nortel 1140E
I want to know how to tune my car audio system without making my woofer clip
Start by turning the amp volume down, clipping is not from tuning its from too small and amp then turning the volume too high or a very distorted signal, this then causes the amp to produce high levels of distortion which cases damage to amps/speakers. Make sure the sub frequency is around 60-80hz and the volume is no more then 3/4 of the way up. You may also have a bad signal from your radio or bad RCA cables but I would start with the amp gain first...
Nov 02, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Does not ring
The Volume key allows you to adjust the volume level for the currently active audio device (handset, headset, or speaker). When no audio devices are active, pressing the Volume key adjusts the ringer volume.
Adjusting the Volume of the Ringer, Handset, Headset or Speaker
Note: By performing this function, default volume level will be replaced.
  1. Press the up or down arrow at either end of the Volume key to reach the desired volume level.
  2. When you are satisfied with the setting, press the Save softkey.
Note: When adjusting only the ringer volume, there is no need to press Save. The settings are automatically saved upon adjustment.
See the below link for user manual
http://noc.unet.maine.edu/IPT/7961_7941_User_Guide.pdf
Jun 20, 2009 | Cisco 7941G IP Phone
LG KC910 Renoir RIngtone Volume
it might be the ring tone you have, i had the same problem but when changed the ring tone to a music tune i had downloading or bluetoothed it was very loud
Jan 14, 2009 | LG KC910 Renoir Cell Phone
My razr does not ring when someone is calling
volume may be turned off or down or it is set on silent. go to settings, go to ring styles, select style and edit/add. scroll down to the ringer of choice and hit select. hopefully that will work. also try the volume on the side of phone. by pressing top left button, you can change ring styles that way.also controls volume.
Jun 27, 2008 | Motorola Audio Players & Recorders
Volume is not working correctly...getting lower
Is your set connected to a cable box? If so then the box itself could be causing your problem. Some of the boxes have their own volume controls. Otherwise you could have a problem anywhere from the rf input to the audio amplifier section. A tuned circuit could be drifting off frequency in the tuned part of the audio circuits. You'd need to have it checked out by a technician. Stargazer
Mar 14, 2007 | Emerson EWF2703 27" TV
Nokia E71 Smartphone Logo
120 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
