Question about Canon PIXMA iP4300 InkJet Photo Printer
Trying to print onto DVD using Disclabel. I load the disc in the tray, open the front door , place the tray, click "print". Yellow light flashes 6 times and I'm told "front door is open, remove the tray, close the front door, press resume button and printing will resume". But I don't want to print onto paper! I'm using Mac Snow leopard with the driver that came with it. Should I download the driver direct from Canon?
  • 10,421 Answers
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
How do I print onto cd?
Please follow these steps:
1.
Turn your printer on. Most power buttons are located on the top of the printer. Press and hold down the button until its LED light turns green.
2.
Choose the image or text you desire to print onto the CD. On your computer, open the image or text you desire to print. images should be opened by clicking on your computer's "Start" icon and selecting the "Pictures" tab folder within the Start menu. When the Pictures folder opens, click on the image you desire to print onto the CD to enlarge it. If you are planning to print text onto the CD, open the text in Microsoft Word or any other desktop publishing program you may have on your computer.
3.
Insert the CD into the printer. Press the "Eject" button that can be found on your CD printing enabled printer. A CD tray will open automatically. Place the CD into the tray print side up. Close the CD tray. The printer will begin working to detect the CD. Once the CD is detected, your printer's LED light will either flash green or another indication color.
4.
Print the image or text onto the CD. For image printing, click on the enlarged image's tab that will be on your computer's taskbar. You will see a horizontal row of action icons below the image. Click on the thumbnail image of a printer to print the image onto the disc. For text printing, simply click on the "File" action on the navigation menu in your desktop publishing document. Click "Print" within the "File" drop down menu. The image or text will be sent to the printer once you choose the "Print" action.
5 .
Remove the CD from the printing tray. The CD will be fed through the printer during the printing process. Once the process is complete, the CD will come through the bottom of the printing tray. Take the CD from the tray when it reaches the bottom.
The above mentioned steps must help you. In case of any difficulty please revert back.
Apr 08, 2011 | Canon PIXMA iP5300 InkJet Photo Printer
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
My DVD drive does not open
Yes, there is a manual way to open it. On most DVD players there is a small hole underneath the door. Push a paperclip in there until the door pops open a little. Then, pull open the door and remove your disk.
May 29, 2009 | Philips DVDR 520 (DVDR520) DVD+R Storage...
DVD label won't print, tray is rejected, 6 orange flashes (cover is supposed to be open)
I've got this printer with no problem.
Make software ready to print with dvd cover closed and press print wait until software tells you to open drawer the place tray up to white arrow's and press print
Should work
Apr 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Do you know how to print on a CD/DVD?
I have just bought the same printer. if you have found out how to do this then excuse me. It isn't clear cut but basicaly all you do is :-
1/ Make sure you have a blank label stuck on your disc, you can also buy printable discs.
2/ Place the cd onto the cd holder label side up.
3/ Pull the front cover down - where the paper comes out.
4/ If you look carefully further inside where the paper comes out you will see another flap/cover - carefully pull that down.
5/ you will notice 2 little rollers and an arrow next to the right hand roller.
6/ place the cd tray carefully onto the rollers and align the arrows on the tray with th one on the ptinter.
7/ now your set for the software - open the CD Label Print software - click on new - click on image tab - and either image file or if it is from the scanner then select twain capture - if you select image file then either make your own image for the disc or select an appropriat file from the browes button.
I won't go on any more but just experiment, you will soon see how easy it is.
Happy Printing
Oct 24, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP810-CD-R Tray loading-printing problem
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
121 people viewed this question
old marine
old marine
