Question about HP DeskJet 920c InkJet Printer
The band is loose
The band inside the printer is loose
Try to find a spare for the band.
Posted on Feb 18, 2008
Es2 300x gateway drivers
As soon as the alignment sensor does not work correct, or does get information it does not expect you get an error.
The band whit the very small lines on it, should be clean and in one piece. It is connected to the print head and registers the slightest movement of the head. Check if the band is there and if it looks "new"
Jul 23, 2014 | Kodak Esp 1.2 All-In-One Printer
Cover removal
If you printer cover loos or not proper set then i suggest you change or replace it. Ya contact Lexmark printer Technician and checking it. If technician ask change then change it.
Thanks,
Lexmark Support
May 22, 2014 | Lexmark X83 All-In-One InkJet Printer
Broken Lexmark X9350 printer
That is the print head band and gear.. You said it was new? I would be calling Lexmark for warranty support as that should not be that way. So to answer you question it goes inside and connects to two pullies to move the head back and forth.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 30, 2013 | Office Equipment & Supplies
Monarch 9825 Thermal Label Printer: my monarch 115 pricing gun, the numbers reels gett...
You may wish to have Avery Dennison, the folks that purchased Monarch/Paxar, to service your printer.
Their phone number is 1-800-543-6650 and ask them the correct address for service. Your bands may be getting too loose, and need to be replaced. If it is something that they can instruct you to take care of, they can sell you the bands and provide instruction.
May 06, 2010 | Paxar Monarch 9825 Thermal Label Printer
There is a loose ribbed black/brown thin band inside the printer where the cartridges are changed-where does it belong please
Sounds like the carriage belt, it goes around a motor pulley on the far right side, and around a spring loaded idler pulley on the far left. It should also be connected to the carriage assembly to move the carriage back and forth.
Dec 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
A round band came loose during a wash. It is a think black rubber-type band. The band is in tact it just need to be put back on, however i dont know where it came from. Dishwasher is a small version if...
That sounds like it came off of your small apliances (blender, food prosecer...) there is not any rubber washers on the inside of 99.9% of dishwashers becauss thay can melt in the heat.
Sep 12, 2009 | Dishwashers
The carriage stuck and I found this band with hole in both ends hanging loose. I need to know how to reconnect this band so printer will work. I cant see where this connects
You can reattach this band yourself. There are two springy hooks on each side of the printer. They are slanted so that you can position the band with the right side forward.
The band engages in a slot in the cartridge carriage, you have to slide it through. I don’t know whether you can fix the band on the right without taking off the cover of the printer. If you must, then follow the procedure:
1. Open the top cover and unscrew the two screws you find there.
2. Open the back of the printer, locate the two release latches left and right press them and lift the back a couple of millimeters (1/8”)
3. Through the top opening locate the two front latches (plastic tongues) release them by putting a screwdriver blade in the catch and pressing forward.
4. Pull the cover gently there are cables attached to it…
Jul 27, 2009 | HP DeskJet 970cse InkJet Printer
Samsung CLP300 cannot get the rubber pick up roller back in
The rubber band goes around the plastic roller and is loose about loose enough to get a finger between it and plastic however the thing then pushes back into the curved space at the back of the roller so it forms a kind of c shape around the roller. If that makes any sense!
Aug 16, 2008 | Samsung CLP 300 Laser Printer
X 1150
That's the "encoder strip" which tells helps the printer cartridges know where they are. It runs the length of the printer and runs through the cartridge carrier. There should be some places to attach it on either side of the printer, although you they may be difficult to reach without opening the printer by removing some screws.
Apr 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP DeskJet 920c InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
