Question about Microwave Ovens
Samsung MicroWave Mod# SMH7178STD Ser# 7MTY3020IT Turns on automatically when you shut the door,you can push and pull on the door until it stops.
  • Jerry Kerns Feb 02, 2010
    Thank You !
    That was some good info!
  • Microwave Ovens Master
  • 19,396 Answers
Hi.
If the microwave is turning on when you close the door, and stays on, even when the timer is off, then it is either a faulty control board, or a contact in the wiring harness.
If the controls are responsive, but fan stays on when you shut the door, then it is definitively a wiring problem. If controls are not working at all, then the control board may also be responsible.
The wiring harness is part 20 on diagram below, here the part: PS942098 . The Latch is part nr.2 PS2160550
Samsung MicroWave
Mod# SMH7178STD
On control assembly, before replacing the pcb (part 7 in diag), the control pad ( part 12) can also be tested, disconnecting it , and starting the appliance with magnetron not connected. For safety reasons this test must be done by a trained technician.
Here all parts and diagrams for your appliance.
For safety reasons testing and repair must be done by trained personal.
Before repairing, I suggest contacting Samsung to get a quote on repair. The contact number is listed on the use and care manual.
Regards.
Posted on Feb 01, 2010
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
My samsung SMH7178std microwave doesn't heat anything up. it makes a buzzing sound after i set timer and press start.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jgk
Feb 10, 2010 | Samsung SMH7178STD Microwave Oven
NEED TO REPLACE KEY LATCH ON DOOR , HOW DO I GET TO IT?
Samsung over- the- range Microwave oven[ SMH7185 STG] won't close.latch?
Jan 02, 2010 | Samsung SMH7178STD Microwave Oven
Samsung smh7150 shuts down after a few minutes.
If the mag overheats because its not being cooled it will shut down until its cool.
If the fan is turning slow you can try oiling it but it likely needs replacing.
Another thing that causes this is that the exaust port is blocked because its upagainst the wall and the hot air can not escape.
Jan 12, 2009 | Samsung SMH7178STD Microwave Oven
Charcoal filter
sami...most of these units use a spring on the inside of the micro to hold the filter frame in place. Push back on the filter against the spring and then tilt it out.
Dec 19, 2007 | Samsung SMH7178STD Microwave Oven
Fan vent door not working
First of all, if it's less than a year old, it will be under warranty and you should contact Samsung to cover the service. You can try the number in your manual or try samsung.com
There is a drive motor that opens and closes the vent fan door. It or an associated switch may have failed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number (SMH7178STD) at http://www.wehaveparts.com
Nov 15, 2007 | Samsung SMH7178STD Microwave Oven
Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
