Question about Canon MX300 Office All-In-One Printer
My pixma mx300 shows 5100 error message, and I don´t know how to go to the service mode, this doesn´t work for me: Turn on the machine Press MENU Press SCAN COPY SCAN to enter service mode USE > to got to NVRAM ACCESS Set ABS-M LEVEL to 0 Set ABS-P LEVEL to 0 Press STOP to EXIT
  • 4,041 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 01, 2010
Service error 5100
hiTurn on your printer
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-Scan-Copy-Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
I hope this helps youRegards
Mar 07, 2012 | Canon PIXMA MP130 All-In-One InkJet...
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Ricoh jp 5000 errore code message ec 5-51
Its a MP5000 right??
You have Loose connection of pressure roller thermistor.
Try this:
Press the clear mode key (yellow key)
Use the keypad to enter "107"
Old down clear/stop for at least 3 secounds (red key)
Enter the service mode (on the touch screen press "copy mode")
Exit all the way to return to the copy window.
Turn the machine off/on.
If doesn´t work you have to call technical assistence.
Feb 12, 2011 | Ricoh Office Equipment & Supplies
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
Hello there ok
Try
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
1. Switch off the Canon MX300 and disconnect the power cable.
2. While press and hold the power button, Connect the power cable to electric socket.
3. While pressing the power button, press the “Cancel/Stop” button (red button).
4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
6. A test page will print.
7. Open the cover, like you are about to change the cartridges.
8. Disconnect the power cable again without switch off the printer.
9. Take out the both cartridges.
10. Close the cover.
11. Connect the power cable and turn on the printer.
12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Feb 07, 2010 | Canon MX300 Office All-In-One Printer
It shows service error 5100 & doesn;t print
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 20, 2009 | Canon PIXMA iP1300 Printer
Error message 5100 on Canon MX300 printer
If the ink cartridges are stuck you can manually slide them back to their default position and check for paper or junk which may have slipped down the paper chute and is blocking the ink cartridges.
Remove the blockage
Reset Printer
Done
I just had this problem and it was easy to fix.
If this not help, buy another printer! Cheaper than service...
Oct 22, 2009 | Canon MX300 Office All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
250 people viewed this question
old marine
old marine
