Question about Ebac Dehumidifiers
Hello there. have a EBAC dehumidifier Model 2800ex. four years old . completly dead no lights at all. Mains to the unit so fuse ok any spares availible or can you fix
Thanks But as the problem was urgent we have bought a new machine
Posted on Feb 02, 2010
Eledtrical
What is the exact model number?
Jul 29, 2013 | Haier 45-Pint Dehumidifier
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
Where can I get a Ebac Dehumidifier filter replacements in New Zealand ?
If your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Noel
noel.bee@xtra.co.nz
Jul 09, 2010 | Ebac HD880 Dehumidifier
Dehumidifier runs but doesn't collect water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2010 | Kenmore 54501 Dehumidifier
Why does my dehumidifer suddenly starting tripping
either the compressor is locked up or the motor start capacitor on the compressor is shorted
Apr 14, 2010 | Ebac HD880 Dehumidifier
Replacement fan motor for ebac homedry 880 dehumidifier. fan motor Mod No aa2c6235
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Noel
Feb 27, 2010 | Ebac HD880 Dehumidifier
I have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and...
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 19, 2009 | Ebac HD880 Dehumidifier
Ebac xl Dehumidifier not collecting water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 11, 2009 | Ebac CS60 Dehumidifier Dehumidifier
My dehumidifier keeps blowing the circuit breaker. It has never done this before - 3 years.
As the unit gets older the motor will cause more load on the circut, also after years of use the breaker will trip easier. Replace the breaker and you may get more use out of the unit but most likely you will have to replace the unit.
Jul 14, 2009 | Ebac HD880 Dehumidifier
Documentation for Ebac 2400E required, please.
Is it possible to download -PDF the Instruction Manual for the Ebac dehumidifier model 2400
May 19, 2009 | Ebac Dehumidifiers
Dehumidifiers Logo
332 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
NOEL
NOEL
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
