Question about HP Office Equipment & Supplies
My hp laser jet 3005 print papers with horizantal lines or repete printing on the same page why that happen? what cause that problem?
    Brigadier General:
  • 3,917 Answers
This print quality problem indicates that a print head nozzle is clogged, this is especially true if your printer has been inactive for some time.
You may need to clean the print head if the ink cartridge has been stored, left empty or not been used for a long period of time. This can make the nozzles becomes clogged with dried ink residue hindering the flow of new ink from the ink tank.
To unclog the print head you need to clean it - either by using the maintenance function in your printer software or by cleaning the nozzles with a special cleaning cartridge suitable for your printer model.
You can try to clean the print head by using the cleaning program that most modern printers have. The cleaning program performs a print head cleaning and several nozzle checks. The nozzle print check should show a correct nozzle printing pattern with lines aligned, no missing lines and no white horizontal color streaks.
Some printers also have a deep cleaning program that does what it says i.e. goes deeper than what the normal cleaning program does. Please note that the deep cleaning program should not be performed more than three times in a row in a short period of time as this might otherwise damage your printer.
While performing the cleaning program, ink will be taken from the ink tank. The amount of ink used in this process depends on how many times you run the cleaning program. You can lower the cost of running the printers cleaning program by installing a cleaning cartridge.
Repetitive defects are almost always caused by the toner cartridge or fusing assembly, and occasionally the transfer roller. If you have an extra toner cartridge or fusing assembly, swap them to see if the problem goes away. Otherwise you can do a half-way test.
A half-way test is a simple test to determine where the print defect is occurring in the printer. As paper travels through the printer, it first passes under the toner cartridge and then into the fusing assembly. Color printers are a bit more complex but the concept remains the same. The idea is to interrupt printing before the paper gets in the fuser. What you do is print a page and open the toner lid when you think the paper is underneath the toner cartridge. This will stop printing and you can pull the toner cartridge out and look at the partially printed paper. It may take a few tries to time it so the paper stops under the toner but not completely into the fuser. If the repetitive print defect is on the page before the paper reaches the fuser, then the fuser is not the problem. It’s probably your toner cartridge or maybe the transfer roller.
Another simple check is to remove the fuser and look at the long rollers in the fuser. If you see toner baked on the rollers or any other gunk then you need to replace the fuser. Fusers with plastic fixing films, also called sleeves, can tear. This usually causes a smear of toner all the way down the page where the sleeve is ripped.
Thanks for contacting fixya.com
Posted on Feb 01, 2010
Why is it printing magenta lines?
Try a different toner cartridge, likely a defective cartridge
Dec 12, 2015 | HEWLETT PACKARD - LASER JETS New - Hp...
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
When I print I only get a line of garmage at the top of the page - i've tried rebooting, etc.
Have you printed a test page without it pluggetd to the computer? What did you get.
Try telling the computer it is a HP Laser jet II
Then print a test page, tell me what you get.
Only put a couple pieces of paper in it just incase it goes nuts.
Feb 12, 2010 | HP LaserJet 1300 Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
HP laser jet 1018 printing problem
Service is required (or a new laser you can now by at very low price)
Jan 30, 2009 | Office Equipment & Supplies
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
19 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
