Question about Audiovox Bosch 718 World Cellular Phone
Boiler making strange vibration noise - Audiovox Bosch 718 World Cellular Phone
    President:
  • 1,738 Answers
Remove the battery and check it for overheating. If it feels like it may be unusually hot, keep the battery out of the phone for 30 minutes and reinstall it. If it doesn't feel unusually hot, keep the battery out of the phone for 2 minutes and reinstall it.
If the problem persists, return the phone for service. Ship the phone with the battery removed.
Posted on Feb 01, 2010
Boiler is about 25 years old no problems since we have had it however when we switch it on and it gets to temperature it starts to make loud whistling noises
check that no wire makes a contact with the cover. check the water pump. does it vibrate when on. it not could be internal corrosion. close ioslator valves and remove to examine
Mar 31, 2015 | Water Heaters
Makes Loud Roaring Noise Driving Dryers Problems with vibration
several things to check, the balance of the legs, the rollers or pulley, the tensioner and the belt, and lets hope not the bearings? something caught in between the tub and housing can make strange noises also. might even check the glides on the tub
Mar 18, 2015 | Samsung DV5451AEW Dryer
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Feb 07, 2014 | Water Heaters
Vibrating central heating boiler
If it sounds like a train it needs a sytsem flush is sluge in there .
Nov 09, 2012 | Heating & Cooling
Hi, I have got very strange noises coing out fromo
I have got the same issue. It sounds like when a motor goes past a point and can't go no further. I don't know anything about cameras and there internal workings, but when you extend the focus ring all the way our and turn the camer on, the camera will not make that noise until the focus ring is back to it's full in position....
Dec 03, 2009 | Sony Alpha DSLR-A200K Digital Camera
Strange wurring sound and slight vibration at full speed Dewalt sds hammer drill dw25003.
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Aug 07, 2009 | Dewalt Drills
Central heating boiler problem
this is probably a faulty diverter valve. more info needed
Jan 02, 2009 | Heating & Cooling
Audiovox Bosch 718 World Cellular Phone Logo
181 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
