Question about BenQ (5232W) (5232W-BULK) CD-RW Burner
Benq 52x32x52 seamless link
We had a virus on our computer which was repaired but now the computer does not recognize that there is a burner connected. We are running windows 2000 Professional NT.
How can I find out if the hardware is installed correctly and why it won't recognize it??
Janet
  • MR R
    MR R May 11, 2010
    Do you mean that you can place a CD in the drive and read the cd but you cannot burn cd's? in Device Manager or even in My Computer does a CD drive appear there? Have you installed the Software for the CD burner and also the software to burn cd's
I have aseamless link dvr 52x32x52 it is not recording, it keeps initialising or resetting
Posted on Aug 08, 2009
What is the position of the link do I need to change to master/ slave etc
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Have not the drivers of Benq DVD LS and my Nero does not recognize the Light Scribe. Do not know where to get drivers
There are no drivers needed for optical units. If Nero can't recognize it then either Nero is corrupted - reinstall it - or the Benq unit is defective - before junking it try to update its firmware
http://drivers.softpedia.com/get/FIRMWARE/Benq/Benq-DW1655.shtml
Oct 27, 2010 | BenQ DVD BURNER |DW1655 BK LS R (DW1655BK)...
BenQ DVD burner EW1621 download software.
all burners are compatible with all burning software..
The thing is some software are free while other you have to pay for,, I'm posting a link to a set of free ones i use..
free dvd maker (3 clicks )
make you files into dvd video's
http://protectedsoft.com/products.php
here is one of the best!!!
compile audio cds, dvds, copy burn rip
http://www.amok.am/en/freeware/amok_cd-dvd_burning/
enjoy the free software..
Mar 17, 2010 | BenQ (EW16210C2) DVD±RW Dual Layer...
BENQ 52x32x52 does not read, - what now?Is not shown in control panel and will not read a disc!
Try to clean it with a cleaning CD, following the instructions on it. If you feel confident you can open it and use a dry ear-cleaning stick to carefully clear the lens, it is better, less chance to scratch it. Next, check for a loose/defect data cable, try the other IDE channel of the mainboard.
Nov 08, 2009 | BenQ Computers & Internet
External cd-rw with no instructions may be missing a cord?
You need the USB cable to use it. Go to a computer store, show them the drive and tell them you need the cable
Nov 05, 2009 | Lite On Lite-On: Lite-On 52X32X52 External...
Benq EW1621 not recognizing any disc/media
not only driver but the proper application software would required for the purpose. install application like nero and burn.
Feb 27, 2009 | BenQ (EW162I) DVD±RW Dual Layer...
Is the Lite-On Combo SOHC-5236k a DVD burner?
technically, this is only a DVD combo, meaning you can read but not burn DVD's with it. only CD-RW CD-R (or any blank cd's can be burn into this).
Jan 11, 2009 | Lite On SOHC-5236K CD-RW+DVD Combo...
How do I install a DVD drive as well as my CD-RW?
mst...First, get your manual out. the drive must be set to be a secondary device unless it is not. You say you have only one IDE...did you remove the CDR? If you have a second IDE or other board connector, then this drive is primary on that. Now, did you install the drivers for the unit? You can use your CDR to do that or get them from the website of the manufacturer. Are there any bent pins on either the motherboard or the back of your drive? Somewhere in there is an answer.
If you have only one drive connector set, you can get a board which will allow you to setup additional drives. Ask your dealer.
Dec 17, 2007 | Computers & Internet
Dvd drive
Hi
Follow this link, although the heading may not seem like the issue you are facing however it should be able to fix it.
http://support.microsoft.com/kb/314060/en-us
Thanks
Sammy
Nov 25, 2007 | ASUS 52x32x52 (CRW-5232AS) QUIE TRACK...
Dvd burner
Hello ublkn5, i have the solution for you. The philips dvd8801 is a Benq 1650.Go to the BenQ website and run their firmware check program and it will recognized your drive as a Benk 1650 drive and it will indecate the latest firmware for it. SO you have to grab BQFlasher from here: http://quikee.cdfreaks.com/BQFlasher.rar Grab the official firmware upgrade from BenQ (BCHC),unzip both, open BQFlasher, select the official BenQ BCHC.exe file with it, and flash away. hope this will fix your problem. best regards AMINE
Aug 21, 2007 | Philips DVDRW 416K (DVDRW416K/00) DVD+RW...
BenQ (5232W) (5232W-BULK) CD-RW Burner Logo
1,276 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
