Printer asking me to Load MP Feeder with A4 - the
Printer saying Load MP Feeder with A4 - the tray is full with A4 paper and the papertray is set to A4
Factory reset should fix it unless the paper size ciruit board and levers have been physically damaged (back left on the printer in paper tray slot)
Posted on Jun 10, 2010
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Load mp feeder with a4
find the switch and turn it to auto paper in the printer settings, mp is for manual paper feed ap is probally for auto paper feed, its a guess . hope it helps
Dec 01, 2009 | Lexmark Office Equipment & Supplies
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
My lexmark t520 says "load mp feeder letter"
Easy one. Open your tray back up and make sure that the paper settings are reflecting the type of paper that is in the tray. The times that I have seen the issue that you just described, the paper setting were off... thus causing this issue.
If that does not work. Powercycle printer. When it comes ready go to the Paper Menu, then to Default Paper source. Make sure that setting reflects the tray that you would like the printer to print from.
Hope that helps.
Mar 19, 2009 | Lexmark T630 Laser Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Jul 29, 2008 | Lexmark T644 Laser Printer
Sounds obvious
Your printer is set to load from MP feeder, either you load the A4 in the MP feeder or change from the paper menu which tray you want the printer to print from .
Regards
Ashraf
Apr 03, 2008 | Lexmark T640 Laser Printer
1,337 people viewed this question
jasbo
jasbo
