Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
HP zv5000 laptop motherboard removal
Is it difficult to remove a motherboard, I have to remove this and ship it out to have the AC Jack replaced, should I be watchful of anything.
  • 115 Answers
Yes this is little bit tough to remove it, you have to take care when you remove it from laptop, firstly you have to remove your keyboard from laptop. After that you open all the screws.
Regards
Ashly
Posted on Feb 01, 2010
Testimonial: "Thanks Ashly I didn't know you have to remove the keyboard as well."
  • HP Master
  • 12,061 Answers
Just be gentle Don't pull anything hard most stuff sort of "Falls apart" and doesn't require much force. Draw diagrams too, don't rely on your  memory.
Testimonial: "Thanks Silverdragon, I wasthinking of using a camera and taking either a video or pictures of each step. Like you said don't rely on your memory."
My HP laptop will not turn of even when plugged in
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Feb 22, 2013 | HP Pavilion Computers & Internet
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
My hp compaq tc4200 wont turn on.if i plug power cable it shows charging after few seconds it wont charge i removed battery but the problem still
Possible causes:
1. Test your compaq tc4200 power supply with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Jan 08, 2013 | HP Computers & Internet
My laptop won't startup
Possible causes:
Hope you just need to replace the hp power supply to fix this problem.
Dec 11, 2012 | HP Computers & Internet
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
My hp netbook wont turn on, what shoud i do?..
Possible causes:
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Nov 05, 2012 | HP Mini 210-1030NR Netbook
How do i get my hp pavilion zv5000 to run on ac power only. it will only run on the battery.
Zv5000 Laptops are plagued with problems related to the jack on the back of the computer. After prolonged use the jack tends to make the solder joint loose. Jacks can also go bad. The solution would be to check if the power comes on momentarily when wiggling the plug in the jack, if the power comes on intermittently then chances are you have a loose solder joint and may need repaired by a qualified tech. Fortunately, for the technically savvy this may be done carefully provided the proper static sensitive precautions are taken, due to the fact the computer must be totally dismantled to get to the jack and properly inspect the solder connections and repair or replace the jack. Silver heat sink compound must also replace the silicone on the processor ( one dab and compress, do not spread compound!) The jack need should it be replaced can be found on Ebay
Aug 05, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Ac power problems
For $75.00 bucks I wouldn't even open it up... lol Thats a good deal if they do a good job. Thats a fair price too I charge like $65 - $80 and hour depending on what is being done. remembering of course we often in actuality often work on something for 6 hours, and only charge 2 - 3, because a job is worth what a job is worth.
Jan 31, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Power jack is loose...
Depends on if it cracked the motherboard with it. If it did it will have to be replaced as well.
Jul 21, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
658 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
