Question about Samsung LN-S2651D 26 in. LCD Television
I plugged my 110 volt samsung 26 ln-s2651d tv into 240 volt ac. fuse? transformer? or garbage?
  • Samsung Master
  • 12,061 Answers
A lot of times it only pops the on board fuse, or if it has a transformer,  then it often simply "Blows" the Primary windings and not too much happens on the secondary, If it is a switchmode well then you probably will have to replace the entire thing.
Posted on Feb 01, 2010
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
My samsung LN-S2651D Comes on with perfect picture then after 5 minutes or so picture strarts to get white snow going down the screen
Tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Samsung LN-S2651D 26 in. LCD Television
I have a Samsung LN-s2651d LCD tv that black screened on me and I don't know if the sound works because I have the internal speakers turned off... I use 5.1. I have been told that it is the t-con...
Do flashlight test on unit. If you can see an image thruout screen the problem is with the tcon board. If no image then it is the inverter board/circuits.
Sep 12, 2017 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-S2651D will not turn on and red light blinks three times.
Tries unplug,replug the tv back an hour later.The tv now,is resetting itself back to factory.Tv should work now.Not,than the power supply board,have problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 11, 2010 | Samsung LN-S2651D 26 in. LCD Television
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Can't get HD cable channels on Samsung TV
Have you check with the cable company to make sure they are broadcasting to you in HD ?
It takes more bandwith so some cable companies will charge extra for it so you will have to check.
Apr 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
I want to operate a LN-S2641D in Australia. I have 240 to 110 Volts transformer but when I plug in to Australian signal it has no colour . I am wanting to use the Samsung LCD as a monitor receiving a...
Go into settings menu on your screen setting and change the PAL/NTSC settings Aust uses a different format to the US. Try "Auto" first if you have that option.
Mar 26, 2009 | Samsung LN-S2641D 26 in. LCD HDTV
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-S2651D 26 in. LCD Television Logo
130 people viewed this question
Jerry Greenberg
Jerry Greenberg
