Question about Compaq Armada E500 Notebook
How can i enter to it's setup? - Compaq Armada E500 Notebook
    Guru:
  • 170 Answers
DEAR BROTHER,
PRESS 8 OR PRESS DELETE BUTTON AGAIN & AGAIN WHENEVER U WILL NOT GO TO SETUP
THANKS ALOT,
SANJEEV KUMAR,
Cell.No.+919876388918
Posted on Feb 01, 2010
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Aug 09, 2014 | Dell Microsoft Windows XP Home Edition
Hp8470 how to enter in bios
You asked this in the Mac Laptops area.
However,
To access the BIOS Setup, turn on the computer and repeatedly press the esc key to enter the Startup Menu, and then press the F10 key to enter the BIOS setup utility.
Figure 1: Example - BIOS Setup Utility
c02258786.gifThe BIOS Setup window consists of options for Security, System Configuration, and Diagnostics.
All the best to you,
Kerry
May 27, 2014 | Computers & Internet
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Enter bios password
If you want to add the BIOS password:
  1. Restart the computer.
  2. At the SONY screen, press the F2 key.
  3. In the Setup Utility window, press the RIGHT ARROW to select Security .
  4. On the Security menu, press the DOWN ARROW key to select Set Machine Password .
  5. Press the ENTER key.
  6. At the prompt, in the Enter New Password field, enter the desired password.
  7. Press the ENTER key.
  8. In the Confirm New Password field, retype the same password.
  9. Press the ENTER key.
  10. At the Setup Notice prompt, press the ENTER key. NOTE: To set a user password, repeat steps 4-10, selecting the Set User Password option.
  11. Press the F10 key.
  12. In the Setup Configuration window, press the ENTER key.
  13. Press the RIGHT ARROW to select Exit .
  14. Press the DOWN ARROW key to select Exit Setup .
  15. At the Exit Setup prompt, press the ENTER key.
If you want to remove the forgotten BIOS password:
Please call 888-476-6972 and speak directly to a Sony® support representative for further assistance. A resolution for this issue is available, but for security purposes, this resolution can only be provided by a support representative.
Jun 12, 2010 | Sony VAIO VGN-N385E/W Notebook
Change fax number
1 Press Setup. 2 Press 3, then press 2. This selects Basic Fax Setup, then selects Fax Header. 3 After Your Name appears, enter your name using the numeric keypad, as described in the next section, enter text, then press Enter. 4 Using the keypad, enter your fax number. 5 After you finish entering your fax number, press Enter.
Apr 04, 2010 | HP PSC 2210 All-In-One InkJet Printer
How do you enter setup on a compaq evo n115
If you system has windows XP as Operating system, press F1 at the compaq screen to Enter Setup
For vista press F10 to Enter Setup.
Please get back for any further assistance
Mar 02, 2010 | Compaq Evo Notebook N115
Apple mac book : how to enter the bios setup
When you power up the computer press F2 or "del" or F5 or F12 or TAB key to enter in bios.
Thanks for using fixya.
Please rate this solution if it helps you.
Jul 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Compaq Armada E500 Notebook Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
