Question about Lenovo ThinkPad SL400 Notebook
The point to which AC adapter connects to my SL 400 laptop is loose or broken. I am required to hold it tight so that battery can be checked. What can I do to ensure it is loose or broken. If it is broken, will it be a part replacement or I will need to replace the whole motherboard (as in certain cases) it is attached to the laptop. Any help in this regard would be appreciated.
  • 838 Answers
Hi, Thanks for joining fixya.
Because you required to hold it tight in order to check the power, I think it's not broken but loosen. No need to replace the whole motherboard. Just remove and replace with jack/point.
For more assistance please stay connected with Fixya.
Have a nice day.
Posted on Feb 01, 2010
Toshiba Satellite L505DGS6000 Laptop will not turn on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
Replacement Toshiba Satellite L505D AC Adapter 120Watt 19V 6.3A
Oct 28, 2012 | Toshiba Satellite L505DGS6000 Notebook
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
Cq61 laptop battery issue
According to the sympton you have described, the most likely issue is your laptop charger failure. Considering replacing a new one:
Replacement Compaq Presario CQ61 AC Adapter 90Watt 19V 4.74A
Replacement Compaq Presario CQ61 AC Adapter 65Watt 18.5V 3.5A
Oct 25, 2012 | Computers & Internet
My laptop wont start even though the light indicator in the charger is on
You may first try performing the steps mentioned below:
1) Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
2) Verify the correct AC adapter is being used, and not a third-party replacement AC adapter.
3) Do not connect the AC adapter to a surge protector or extension cord.
4) If the DC jack on the computer is loose or damaged, the computer may require service.
5) Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced.
6) Attempt to turn on the computer normally.
7) Press and hold the Power Switch for 5 seconds.
8) Remove the battery.
9) Disconnect the AC power adapter.
10) Press and hold the Power Switch for 5 seconds.
11) Connect the AC power adapter.
12) Attempt to turn on the computer.
NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
13) Disconnect all external devices that are connected to the computer.
14) Attempt to turn on the computer.
15) Remove any additional Random Access Memory (RAM) that was installed in the computer.
16) Attempt to turn on the computer.
17) The troubleshooting steps listed above should resolve your issue.
If you have completed all of the steps and the issue is not resolved, service may be required.
Jul 06, 2010 | Dell Latitude D600 Notebook
My computer is not detecting my battery. Also it appears not to be charging
Hi, Shutdown the system , and disconnect the battery from the laptop.Also disconnect the Ac adapter. There is a button the battery , press and check if there are any light the glow on the battery. If there are no lights that glow the battery is dead.
Press and hold down the power button for 10 sec. after removing the battery and the Ac adapter Reinsert the battery and connect the Ac adapter 1.Power on the system and tap on f2key slowly five to six times on the Dell logo screen 2. You would enter the blue screen 3. Using your down arrow key, go to the option that says battery info or battery health . Check if there are any error messages on the same. If the battery is not detected you would have to replace the battery
** Note ** normal life expectancy of the battery is one year.
Thanks for using fixya Porton 2
Nov 11, 2009 | Dell XPS M1330 Notebook
It seems that my laptop want go to ac (adapter) and shuts down
Most likely your problem is caused by a loose connection on the main board of the laptop. Even though it will plug in to the connection, the connection on the mainboard is either cracked or broken. Laptops are VERY hard to work on and you need to find a authorized repair shop for that brand computer in your local area to properly fix this problem.
Dec 22, 2008 | Acer Aspire 3000 Notebook
HP home edition ze2308wm keeps seitching from AC to battery
The soldier holding the DC jack on the machine has broken loose. If you can, you should take it back to the place you had fix the jack and have them resoldier it. These are very small connection points, and if they don't get the soldier in there good, will break loose. It's a common occurrence, I've had it happen to a few of my soldier jobs, they should take care of it. Be careful with the way it is now, you can do severe damage if the connection point gaps and creates an electrical arch. I would suggest not using it until you get it fixed.
Jul 15, 2008 | HP Pavilion ze2000 Notebook
Computer start-up
ok...try this without battery, only with ac power pack plugged in.
got backup?
Feb 11, 2008 | HP Compaq Presario V2000 Notebook
No power when at switch on
Sounds like the power socket on the laptop may have broken loose from the board. Very common. If you have a multimeter, try and check the voltage ont the tines where the main battery receives it's charge, with the ac adapter connected to the laptop. That will tell a lot. Good luck
Jul 25, 2007 | Acer TravelMate 290 Notebook
Lenovo ThinkPad SL400 Notebook Logo
21 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
