Question about Nokia 2100 Cellular Phone
I need voltage level of ringing circuit nokia-2100 when it is ringing
  • 56 Answers
It is very old handset what is ur problem if ringer is not working properly then u have to change ringer only.
Posted on Feb 01, 2010
I have a ring notification tab stuck on my Nokia 1020 that will not disappear and the phone has no audible tone on in coming calls
Have you tried a hard reset? Have removed the battery? Best bet is use Software Recovery Tool for this. Not sure you get it from Nokia or Microsoft. It has fixed many problems.
Jan 27, 2015 | Nokia 1020 Black 32GB Factory Unlocked...
Nokia 2100 dead werno po
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 18, 2011 | Nokia 2100 Cellular Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
I have nokia 6120c charging shows but not store on battery even i changed new battery please help!
You will need to check your adapter and also the voltage that comes to the battery at the charging terminals while the adapter is plugged on.
Since your new batteries are also not charging it is possible there is fault in the charger for not providing the sufficient voltage/current to the battery.
Finally it is possible that there are errors in the main board - charging circuit that prevents the desired levels of voltage required for charging.
Feb 04, 2011 | Nokia 6120
How do i format my memory card in phone nokia 2100
Follow this instructions to format your phone
1)press *#7370#
2)enter security code(default code is 12345)
3) Wait a few minutes until the format is complete. Your phone will now be at its original factory setting
Now restore all your ring tones, messages and contacts and you once again have a fresh OS.
Dec 13, 2010 | Nokia 2100 Cellular Phone
Can't off of silence. how do you fix it.
please change ur profile, or change the setting, sounds, call alert, msg alert, and ring tones,
or
switch off ur mobiles, and after this procedure.
Sep 01, 2010 | Nokia 2100 Cellular Phone
My nokia 2100 is not getting on
Your phone might have software or hardware problem , U can find out weather it is software problem by connecting it to a PC trying to flash it ( software installtion .
2, pls check the Bat state if is it having voltage 1, is it charging , using your Multimeter measure voltage from bat contact for 3.6 volts if nothing the phone has hardware problem eg Eprom chip , power IC is damaged.
Good luck dude
Jan 16, 2010 | Nokia 2100 Cellular Phone
Battery Problem
you ust change it into BL-4c, that is the correct size of 2100
Mar 28, 2009 | Nokia 2100 Cellular Phone
LOW VOLUME ON MY NOKIA 6030 CELLULAR PHONE
hi! Goto settings->tone settings->check ringing type in ringing->check the volume level increase the volume level!
Jul 18, 2008 | Nokia 6030 Cellular Phone
Nokia 2100 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
