Question about Sony DCR-HC32E DV Digital Camcorder
The file size of the video imported from DCR-HC32E is huge. A 60 min. cassette is converting 12-13GB files!! Is there anyway to reduce the file size at the time of importing the video. Pankaj
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 220 Answers
You can convert the file to another format or cut the file into several pieces.
Use Video Download Studio to download video to help you with conversion. it can convert between almost all the formats of video and audio:
AVI to WMV, FLV to MP4, MPEG4 to FLV, MOV to MKV, VOB to MP3, etc.
Posted on Apr 02, 2010
computafixa
  • 317 Answers
SOURCE: imovie imports Hi8 tape but not plain 8 tapes
What it is, is the standard 8mm tapes are not digital, and therefore won't import into imovie, unless you have the 8mm to Hi8 option enabled in playback mode, by setting it in the menu, under playback settings.
Posted on Feb 21, 2008
SOURCE: DCR-HC32E
You need a FireWire cable and a computer with FireWire port. I have same camara - it comes with a base unit into which you have to plug in the camara. From that base unit connect the firewire cable (4pin) and take that to your computer which may have a firewire port (either 6pin or 4 pin) - depending on what kind of firewire port you have on the computer, you have to get appropriate cable ... it is my understanding that the camara doesn't come with this cable. I purchased a firewire cable with 4 pin connecter on both ends to connect to my IBM laptop with Vista on it. It works great after all this setups. It does not work with a USB cable for some reason.
Posted on Jul 19, 2008
SOURCE: import videos from handycam to computer
For Sony, use the i.link interface but the computer will also need same interface, otherwise revert to XP.
Posted on Dec 08, 2008
  • 4 Answers
SOURCE: import video from Sony handycam DCR-SR42 to computer
Does your camera having a docking station? If so, press the "burn to disc" button on the docking station, while the USB is connecting camera to computer.
Posted on May 07, 2009
SOURCE: Can't Import Footage Via Firewire with Sony DCR-TRV900E and Vista
Hi nash
I ma having the same problem... Did you get a solution in the end?
Posted on Jun 15, 2009
I'm not able to view and transfer my video films on the computer
How are you trying to make them communicate, are you using a USB?
If so make sure you select the proper action when your PC prompts you. Transferring and playing are two distinct things, that is to say, sometimes you may be able to transfer a file to something but, that file may not play due to compatibility.
Dec 06, 2013 | Sony DCR-HC32E DV Digital Camcorder
Tip
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing <br />Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion <br /><br />The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though <b>Final Cut Pro X</b> with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X. <br /><br />To edit the 1080/60p or 1080/50p <b>Camcorder AVCHD Videos to Final Cut Pro X</b>, the conversion from MTS/M2TS in 50/60 <b><a href="http://www.aunsoft.com/final-mate-mac/">Progressive mode to FCP X ProRes 422 (HQ)</a></b> or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes. <br /><br />The guide below shows you how to <b><a href="http://1080p-converter.com/2011/07/avchd-to-fcp-x-mtsm2ts-in-5060-progressive-mode-to-fcp-x-for-prores-422-hq/">Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X</a></b>. <br /><br />Step 1. <b>Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Run Final Mate for Mac as the best <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Cut Pro X and AVCHD</a></b>, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Choose <b>AVCHD files to FCP X ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly. <br /> <br /><b>Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.</b> <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode. <br /> <br />Wait for the conversion, and you can then import 1080 60p <b><a href="http://www.aunsoft.com/final-mate-mac/">HD videos to Final Cut Pro X</a></b> through the direct import and enjoy editing in FCP X. <br /><br /><b>Tips:</b> <br />If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: <b><a href="http://www.aunsoft.com/solve_no_video_problem_after_converting_avchd_to_apple_prores_for_fcp_x/">Solution to ProRes Video Issue in FCP X</a></b> on aunsoft.com.
on Jul 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for...
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7 <br /><br />Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920&times;1080p at 30/25/24 fps, HD/SD 1280&times;720p/640&times;480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac Canon EOS Converter</a></b> for you to edit Digital Rebel T2i / 550D videos. <br /><br />Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7. <br /><br />Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/convertimport-canon-rebel-t2i550d-108030fps-mov-to-fcp-with-prores-codec/">Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter</a></b> on Mac OS X. Click the "Add" button to import .mov files from the camera. <br /><br />Step 2. Choose MOV format with ProRes 422. <br />Click the "Format" option, and navigate to Final Cut Pro &gt; Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov. <br /><br />You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc. <br /><br />Step 3. Choose 1080p size with 30fps. <br />Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps. <br /><br />Step 4. <b>Convert DSLR video to ProRes 422 HQ MOV for FCP.</b> <br />Click the convert button under the preview window, the <b>Mac Canon 550D DSLR video converter</b> will start <b><a href="http://prores-converter.com/2011/06/eos-converter-transcode-canon-dslr-550d-video-to-prores-422-in-full-hd-1080p-for-fcp-editing/">converting DSLR video to ProRes 422 in full HD 1080p for FCP editing</a></b>. <br /><br />After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon H.264 mov to ProRes 422 for FCP 7 and 6</a></b>, so that you can edit the H.264 files easily.
on Jun 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
I have a Sony DCR-SR43 handycam. I am a amateur photographer. When i shoot some shots, the file size is very large (208 or so..). Is there any software to compress the file.
The size of the file depends mostly on the resolution. Higher resolution gives more detail and the picture can be printed larger without showing pixelation, but this requires more data, so the files are larger. Recent cameras offer resolutions stated in terms of 10 or 14 megapixels. That much data needs a large file to store it. Reducing the resolution in the camera settings to 5 or 3 megapixels (or less) will give you a much smaller file. In the camera, this will usually be specified in terms of pixels wide by pixels deep (e.g. 1600x1200).
You can reduce the size of a picture in a photo editing program (resize or resample), which will also reduce the resolution.
Compressing the file is not likely to help much. Usually these files are in a format (.jpg) that is already compressed. The camera may allow more than one quality of compression. You can set this to compress the pics more, but this will reduce the quality of the image and introduce more digital noise. It is also possible to increase the amount of compression when saving an edited file in a photo editor, by specifying this at the point of saving. None of these will make as large a difference as reducing the resolution by resizing.
Feb 03, 2011 | Sony Handycam DCR-SR42 Camcorder
Resulting mp3 files are HUGE
Are you certain that you're recording in MP3 format?That large file size seems much like .wav files than .mp3 thing.
But if that's really .mp3 file,you may need to adjust the bit rate&sampling rate.Typically, 12 kbps and 44.1 KHz would be a good starting point.
And about shrinking files you've already done,try file convert software(s) around the web(try Google it).Too many of them to recommend here.But I personally use Wavepad Sound Editor for record,edit and save files in various format.
http://www.nch.com.au/wavepad/index.html
Jul 23, 2010 | ION Audio Vinyl Recording Turntable
Tip
Convert/Import Sony DCR-SX/SR/HC/DVD Series to Mac, iMovie, FCP
As we known, Sony DCR series camcorder includes Sony DCR-SX, Sony DCR-SR, Sony DCR-HC, Sony DCR-DVD, Sony DCR-TRV, Sony DCR-VX, etc, and most of Sony DCR camcorders record video in SD MPEG-2 such as some Sony DCR-SX series, Sony DCR-SR series, Sony DCR-DVD series.
Some Popular Sony DCR Camcorder Series in the following:
Sony DCR-SR: SR40, SR42, SR60, SR68, SR82, SR87, SR100, SR200, SR300, SR45E,SR65E, SR87E, SR85E, SR220E, etc.
Sony DCR-SX: SX40, SX44, SX60, SX63, SX83, SX34E, SX40E, SX43E, SX46E, SX60E, etc.
Sony DCR-HC: HC35, HC26, HC28, HC62, HC40, HC21, HC52, HC24E, HC38E, HC54E, etc.
Sony DCR-DVD: DVD650, DVD108, DVD92, DVD850, DVD403, DVD505, DVD610E, DVD710E, etc.
Due to Sony DCR video cannot be directly imported to iMovie, Quicktime, iTunes, FCP, Adobe Premiere Pro and some other popular devices, if you want to import your Sony DCR Handycam SD video to Mac for enjoying or further editing with iMovie, FCP, FCE, etc, the first step for you to do is to convert these Sony SD video to MOV, MP4 for Mac, then you can import converted Sony DCR video to iMovie, Quicktime, iTunes, FCP on Mac for enjoying or editing.
To convert Sony DCR series video to Mac, Sony DCR Video Converter for Mac is the best software to transfer these Sony DCR SD MPEG-2 video, Sony AVCHD MTS, M2TS files, and some other camcorder videos to MOV, MP4, MPEG, 3GP, M4V, etc on Mac. Besides, you can also convert and import Sony DCR SD video to iPad, iPod, iPhones (including iPhone4), PSP, Blackberry, and other mobile players.
How to Convert Sony DCR video to Mac OS for further editing with iMovie, FCP, etc?
Step1: Add Sony DCR Video on Mac
Click "Add File" to upload your chosen Sony DCR video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step3: Convert Sony DCR Video to Mac OS
Press the "Start" button to convert Sony DCR SD video or AVCHD MTS/M2TS files to Mac. After conversion finished, you can enjoy converted Sony DCR video on Mac or edit these videos with iMovie, FCP, FCE, iDVD, etc.
Related: How to Convert and Edit Canon VIXIA HF Series to Mac?
How to Convert and Edit Panasonic HDC Series to Mac OS?
on Oct 26, 2010 | Computers & Internet
Sony dcr-hc32e vista driver ,
Go to camcorder Menu and enable USB Stream.
Windows will recognize camcorder.
Aug 12, 2009 | Sony DCR-HC32E DV Digital Camcorder
Trying to get the video from my Sony Handycam (DCR-SR47) to Mac
Sony Handycam (DCR-SR47) creates MPEG-2 video, just convert it to QuickTime (.MOV or .MP4) video which you can import to Mac.
Try this Sony Handycam video converter for Mac.
Jul 13, 2009 | Panasonic SDR-H40 HDD Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Sony DCR-HC32E DV Digital Camcorder Logo
107 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
