Question about Epson Office Equipment & Supplies
Hi my scanner froze in the middle of copying and now it wont move and led screen say's printer error
Try to restart it
Posted on Feb 01, 2010
Canon c130 copier stuck in middle of copy
Hi Ben,
Please Watch This video and fix your issues.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Mar 04, 2014 | Canon C130F Black and White Copier
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
Dear sir, i have a problem in my toshiba estudio120 printer it displays in screen L1. How can i solve this problem to work printer. Plz help me.
Hi:
L-1 means that the scanner assy is not moving correctly. There is a scanner lock in the cavity where your copies come out. Just bend over and look up in the cavity and you should see a round knob. It has a lock and unlock icon. Make sure that is completely unlocked. If it is partially locked then this will keep the scanner from moving and cause the L-1 error.
Andrew
Aug 08, 2010 | Toshiba e-Studio120 Copier
My hp psc 1350 printer scanner copier wont scan anything but it will print and copy
When an ink tank becomes empty.
("No ink error" displayed on the
monitor or on the machine LCD, or
short flashing of an ink tank LED)
Oct 08, 2009 | Office Equipment & Supplies
Trying to copy something and this error 2200 pops up and states refer to user guide
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
Apr 22, 2009 | Lexmark X7170 All-In-One InkJet Printer
How can the Error 2200 be fixed? Lexmark X7170
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge.
Mar 31, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Error 2200
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Maggie B
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
55 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
