Question about Electrolux Cooktops
Hot plate cooktop malfunction?
I used the hot plates cooktop last night and went to use it tonight and the system does not turn on, no response.I have recently purchased a property with the schott ceran stove top installed. This problem has occurred previously and I had an electrican attend. The electrician was not sure but somehow from checking the wiring fixed the problem. I don't have any make or model information apart from the schott ceran logo affixed. I fear the system may have shorted for some reason please help.
SOURCE: I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Posted on Apr 25, 2008
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
Posted on Nov 19, 2008
  • 5 Answers
SOURCE: Hello I have a Miele Deluxe H818 oven
Hallo I have a Miele Deluxe H818 oven too.
I do not use my cooktop because I buy new with gas-metan.The original cooktop is only electrical.
Posted on Dec 14, 2010
  • 1711 Answers
SOURCE: My schott ceran class top stove keeps saying F1 on
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
Posted on Dec 19, 2010
  • 1140 Answers
SOURCE: My miele induction schott ceran
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Posted on Apr 25, 2011
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
Won't switch on
a hob ??? or am i just stupid ??
Nov 23, 2011 | Bosch Cooktops
Hot plates not heating up
Hi kennycrocket,
You might be looking at dead plates or faulty regulators. I'd suggest lifting the cooktop of, and turning it over. Then very carefully, while still on at the main, testing at the power points with a multimeter.
First test incoming power to the regulators (The devices found under the knobs), then testing power to the plates. If power gets to the regulators, but not to the plates - The faulty part is the regulators. If however power goes to the regulator as well as the plates, then the plates are faulty.
Kind Regards
* If this solution helped you, please rate it
Aug 08, 2011 | Belling 23 in. SHU53 Electric Cooktop
I just need to know the cutout dimensions for jenn air smoothtop
i asume that you want to cut your counter to drop the hot plate in turn your plate upside down measure about 1inch smaller than the dimention of the plate is should work fine thanks from gilles
Mar 15, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
163 people viewed this question
Top Electrolux Cooktops Experts
Paul Carew
rugby prop
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
