Question about P.I. Engineering PI Engineering X-Keys Stick USB Keyboard
1.How is the s-lay method used in offshore
1.Explain stage by stage of the s-lay method of installation is executed for an offshore pipeline!
2.How are offshore pipeline crossing executed with many pipeline along a pipeline route to the platform ?Is it with the s-lay barge or other lay vessel?
What thing makes your sales pipeline more productive? Explain?
In this guide, we'll take a look at some general tips on how to make sales pipeline more efficient, productive and delightful. Here are those 11 things:
1. Ask yourself this difficult inquiry: is your CRM actually working?
2. Contribute content that is really valuable for your genuine clients.
3. Consider how you measure the quality of your leads.
4. Ensure you can share learnings effectively teamwide?-?and far-reaching.
5. Try not to "cluster" your updates.
6. Ensure your business pipeline is in advance with your clients' "purchaser journey."
7. In the event that you have restricted time to look at your pipeline consistently, focus on early-stage opportunities.
8. Try not to lay loads of channels when a straightforward one will do.
9. Look at your past prospective clients.
10. Updates your record and Clean it out olds.
11. Read genuine studies on deals pipelines.
Still, you want to make your sales pipelines better a relevant lead management software or system, get visit vyakar where your demand will explore to provide the most suitable solution for your business.
Vyakar Realtime Solution For Lead Operations Lead Routing List Matching...
Feb 15, 2018 | Better Computers & Internet
New Goulds 1/2hp water pump w/Square D switch goes on by itself for ten sec. Then off for 5 sec and on for 2sec. 2 minutes later it does it again.Adjuster nuts do nothing to stop it going on again...?
if you are using a pressure tank, that condition is said to be a water lag. Try to drain your pressure tanks using the following steps,
1. remove the drain plug of your pressure tank. (in most cases it is located at the tank bottom just be aware that there might be a pressure still on the water inside your tank so just remove it slowly).
2. remove the pressure gauge using a suitable open wrench.(this is to remove any standing water inside your pressure tank.Same principle as the 2 holes on a can of milk)
3. after all the water has been drained reinstall your drain plug and your pressure gauge.
4 put a water priming on the pump if necessary before starting your motor again.
The condition above is condition 1, if in case you are using a pressure tank.
We will now discuss condition 2 wherein there is no pressure tank installed on your water system.
Your motor can easily run because there is no enough water to use inside you pipeline since there is no pressure tank on your system. In this case, try to install a pressure tank so there will be enough water pressure build up on your tank before using the water on any water faucet.
Also try to check for water leakage along your water pipeline since frequent motor running when not in use of any water faucet means that the water is wasted on some parts of your pipeline.
Good luck and I hope I've enlightened you.
Nov 14, 2015 | Plumbing
How to fix error 2503 in acer laptop
What are you trying to install?
┬ĚDid you get any error message along with the error code?
┬ĚDid you make any changes on your computer prior to this issue?
Let's try these steps and check if it helps.
Method 1
Unregister Windows Installer, and then reregister Windows Installer. To do this, follow these steps:
1. On the "Start" menu, click "Run.
2. In the "Open" box, type "msiexec /unreg", and then press ENTER.
3. On the "Start" menu, click "Run".
4. In the "Open" box, type "msiexec /regserver", and then press ENTER.
Method 2
Check permissions within the Installer folder. To do this, follow these steps.
1.Click on Start and in the Start Search bar > type in > c: /windows/installer.
2.Right click on c: /windows/installer at the top under programs and click properties.
3.Click on the security tab > Verify if System and Administrator account has Full access permissions.
4.The Everyone account should have read and execute permissions, List Folder Contents, and Read.
Jun 11, 2014 | Dell Studio 15 Laptop
Can i just hook it up and run the disk wizard? or is there another formatting ,partitioning tool I should get?
Use Disk Wizard. No 3rd party tools are required at all.
Scenario: 1 Pipeline SATA. 1 Barracuda SATA. 1 IDE drive with current OS. Is this correct?
Just treat the Pipeline from the DVR as an extra drive by formatting it, and moving the files over. You then can remove the IDE and Pipeline for peace of mind, but the OS advance setup should give the option of all three drives for install destination.
Leaving the IDE drive should not affect your resources.
Oct 25, 2012 | Seagate Technology 500GB Pipeline HD SATA...
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
After taking pictures it come out blurry
1) Make sure all settings are set to "Auto".
2) The picture button has 2 stages, it takes a little practice, but after a while you can feel them.
The first stage tells the camera you're about to take a photo so get to it, setup the focus and set up the exposure setting.
The second executes the photo.
3) What you have to do is pause between stages 1 and 2 to give the camera a moment to focus properly. Then continue with taking the shot.
4) The other thing which can cause blurred photo's is camera shake, try and hold it as still as you can.
Mar 06, 2010 | Nikon Coolpix S210 Digital Camera
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
May 12, 2009 | Ford Escort Cars & Trucks
P.I. Engineering PI Engineering X-Keys Stick USB Keyboard Logo
348 people viewed this question
Top P.I. Engineering Computers & Internet Experts
David Payne
David Payne
Are you a P.I. Engineering Computer and Internet Expert? Answer questions, earn points and help others
