Question about Ovens
Hello,do you know what would cause the following problem in an Electrolux Cooker,MODELNO: DD061, PROD NO: 948522135, SERIAL NO: 42900006. THERE IS AN ODD TASTE OFF THE FOOD WHEN COOKED IN THE MAIN OVEN?
  • clare120 Feb 08, 2010
    The appliance is electric. I've phoned Electrolux and they have not come across this problem before. They advised for the appliance to be cleaned really well, especially the vents at the back of the oven. This has been done but makes no difference. The oven was switched on for 2 hours as well on high heat to make sure the stay clean liners were cleaned well but unfortunatly problem still there. The taste of the food is metallic. I'm at a bit of a dead end now I'm afraid.
  • 73 Answers
Is it a gas range?are you getting soot? you need to look at flame while unit is on, remove oven botton to expose the burner, easy!!!! 2 screws on back inside over and pull bottom up. shut door turn on range and look at flame if it is yelolow and long flames you need air ajustment at burner, inside very bottom door you will see the air shutter, open it a litttle if falmes are yellow and long and test it again.
Posted on Feb 06, 2010
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
After 30mins the oven goes off, what is the problem
Hello,when you opened the top you will find a small insulated plastic tube with two thermostats in side and maybe one of them was burned out,this assembly must be replaced with a new one ,they are all push on connections and are easy to replace turn the cooker switch off for oblivious safety
Thanks
May 28, 2010 | Electrolux EOB6632 Electric Single Oven
Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
May 11, 2010 | Electrolux ICON Designer E30SO75ESS Oven
How do i turn the fan off.
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
May 07, 2010 | Electrolux EOB6636X Ultrafan Electric...
AEG Oven model D98000VF - error code F8 on display. All functions failed (no grill,ovens,hob)
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
May 02, 2010 | Electrolux Ovens
Hello, I have a Soutbend cooker serial N° NX
Call Rick at Restaurant Parts and More. 1-888-814-1110
Be sure to have model and serial numbers to ensure the correct part.
Nov 18, 2009 | Southbend S560DD (Gas) Oven
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Beko Cooker dvc565
once you take of the back of the oven there are some wires going from the cooker to the back cover on one of the wires you will see a microtemp thermal fuse protector this connects the two wires (the white wire) this needs replacing you can get them from tdspares.co.uk we will be getting 121c degree. Hopes this helps
Feb 10, 2008 | Ovens
Ovens Logo
87 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
