Hoover vision hd washing machine was working then tripped power. checked plug socket, plug fuse all working. there is power to machine but no power showing on control panel. could it of blown a relay etc?
  • Washing Mach... Master
  • 3,463 Answers
Could be faulty door interlock, as nothing will work until this activated..
On the other hand, could well be power module or display module that is faulty.
The only thing thing you can do at the moment is to remove the top cover, and see if there is anything obvious looking in at the top
Hope this helps.
Posted on Feb 01, 2010
Where do you find the fuse in a hoover vision hd 7kg washing machine?
USUALLY LOCATED IN THE PANEL BUT WHICH FUSE ARE U TALKING ABOUT
Feb 20, 2015 | Hoover Washing Machines
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
Hoover primera washing machine keeps tripping electrics when tured on.
Possible that there is higher current drain which trips off the circuit. This can be due to moisture or dampness in the circuit , coils or the motor. You need to remove the top panel and dry using a dryer. check the connectors, check the main line , the motor circuit. Isolation of the motor or the heater can confirm the short if the circuit stays. Check the main power to the panel and allied circuit for possible capacitor leak or short.
Mar 16, 2013 | Washing Machines
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
