Question about Microwave Ovens
Zanussi tce 7124 w condenser dryer does not completely dry cloths
  • liammccoo324 Feb 13, 2010
    Hi, just gotten around to this, the heating element is fine and all vents/seals are clear.
    When the cycle ends the water level indicator flashes, and when in there I noticed water lying on the floor of the machine. The reservoir can be empty and this light comes on.
    Am in process of completely drying out the area and changing the seal on the reservoir.
    Is there a sensor down there to make the dryer think that the reservoir need emptied?
  • 776 Answers
You might be facing this issue because of 2 reasons:
1. Make sure your dryer vent is not glugged all the way to the outside first before you do anything else, take an air hose and make sure you have ventilation.
2. Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Also you might want to check for the thermostat as though it is not a common issue one of the thermostats that controls the temperature in your dryer may have broken down and caused the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Posted on Feb 01, 2010
Condensation water build up inside
I will say no as long as things are allowed to dry. So leave the door open for a time if you will not be using it again soon, or use a cloth to help speed up the process.
May 08, 2014 | Microwave Ovens
Not drying clothes. Have checked all filters and water tank. Still not drying :-(
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 21, 2011 | Microwave Ovens
Several buttons on key pad of microwave are not working
Steam got into key pay. Sometimes it will dry out. Take key pad apart and try to dry with a hair dryer, not to hot, you just want to blow condensation out of it. If this does not work, key pad needs to be replaced. The problem is they cost as much as a new microwave.
Sep 27, 2010 | Kenmore Microwave Ovens
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
My Kenmore Elite HE3 dryer is very slow at drying clothes even at the highest temp and seems to be getting worse.
Best guess is your dryer vent might be blocked. Check to ensure the vent hose is clear of lint all the way to its outlet.
Dec 19, 2009 | Microwave Ovens
My electric dryer is takeing to long to dry clothes.
If you are experencing longer dry times, the following link will explain what to do:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Read through the link provided and let me know if you have any questions. Please post back with a model number if you do. I hope this helps you.
Dec 15, 2009 | Microwave Ovens
Dryer seems to be heating but cloths are not getting dry hardly any lint on cleanout screen
Is the air venting all the way to the outside? If you ducting is clogged, dry times will be much longer. You may also be seeing steam come out the door if you open it halfway thru the cycle if vent is clogged. A crimped hose between the dryer and the wall can cause a similar problem. A clogged vent can also be a fire hazard.
Nov 19, 2009 | Microwave Ovens
Matag Dryer sounds like it has a tennis shoe in it.
Bad rollers or blower wheel is worn out.
Nov 15, 2009 | Microwave Ovens
Microwave Ovens Logo
291 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
