Question about Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black
Hi can i connect it to my mac? what cable do i need? thanks jonathan kolber jonathank@violape.com
  • jonathank71 Feb 01, 2010
    thanks! i will try to get the cable; what is the complete name?
  • 2,069 Answers
Yes. Use the Right/left Auxiliary Audio in. female RCA connectors.
hi
Regards
Posted on Feb 01, 2010
Hi i have a 99 r6 and i have no spark to any of the plugs. help please !!
Hi, Jonathan and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/335658-no-spark-troubleshooting-nutshell-may-still-need-help.html
http://pnwriders.com/threads/99-r6-wont-start-no-spark.138195
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Project Yamaha R6 Part
Yamaha YZF 600 R6 5SL 05
Aug 22, 2012 | 1999 Yamaha YZF-R6
Connecting a EVI-D100 to a Macbook Pro Laptop Help.
Hi, I have a Sony EVI D100 that works. I have a Visca USB Cable and an s-Video cable and video cable. I will be connecting it to my MacBook Pro. What else do I need to use this Cam with my Mac to feed video to the mac? I also have a Mini Display Port To AV/CVBS/RCA/S-Video Converter Mac
Jul 29, 2012 | Sony EVI-D100 Webcam
Hi, I am having problem installing Frame.NET.
Well Jonathan ! You did not tell the error you get and which version you are trying to install.
May 01, 2011 | Microsoft Windows XP Home Edition
Hi there, I'd like to connect the Acer S202HLBD 20"" LED Monitor with a Mac Mini which cabling would I need?
It all depends on what kind of PORT connection you have on your MAC either VGA or DVI. If your Mac has VGA port then you need to use the blue cable that comes with your Monitor when you bought if you have DVI then you need to connect the white cable.
How to know if you have VGA or DVI or BOTH.
1. Check the sides of you mac and see if you have a blue port. Blue port means you have VGA port
2. IF you have white then that means you have DVI
3. IF you have both then you just need to use 1 connection. I prefer DVI since its digital.
Your feedback is greatly appreciated. Thank you for using FIXYA.
Apr 23, 2011 | Computers & Internet
What if I want to use internet on MAC using samsung mobile
Connect your phone to the PC using bluetooth or a data cable.Select COM port for data cable and Bluetooth DUN for bluetooth connection on your phone.Follow the service provider's customer service personnel's instruction and you are ready to browse the internet.
Thank You.
Feb 15, 2011 | Samsung SGH-D980 Cell Phone
I need to reconfigure the Netgear router
There isn't really much to configure on a cable modem. If the modem is fully recognized by the cable provider (all lights are lit on the modem once connected to the cable (coax) side), then just plugging in the Netgear router's INTERNET connection directly into the cable modem will work fine. If the modem isn't properly recognized, you'll have to call your cable company and provide them the MAC address of the cable modem. The MAC is a 12 digit hexadecimal (0-9,A-F) number that should be on a sticker on the modem itself - it will be listed as six pairs of hex digits. If the cable company doesn't have that particular MAC address attached to your cable account, then it won't work.
Nov 10, 2009 | NetGear RangeMax WPN824 Wireless Router...
What else do i need.......bought airport card. not sure what router I need and if I need an adapter?
Hi I'm mhel, you have to buy a wireless router and a hub to connect both your desktop and laptop
mhel
mhel_services@yahoo.com
May 31, 2009 | Apple iBook G3 Mac Notebook
I want to connect my Macbook Pro (Mac OS 10.5) with my Onkyo Receiver via Toslink optical cable. How could I do?
There is an optical cable that you can buy. It needs to have a MINIPLUG on the one end and a standard Toslink on the other. This will give you the digital audio out of the MacBook Pro.
A company called Proel make the cable you need in varying lenghts.
www.proelgroup.com
Hope this helps
Verb
May 26, 2009 | Apple MacBook Pro Notebook
Calibrator talk doesn't see monitor on mac
did you verify that the USB port is active and the cable is working? Check under the Apple menu for "about this mac" then click on more info. Click on USB to see a list of active USP devices. If the Barco is connecting it will show up in the list. May not say Barco, it may say unknown device but it lets you see that the cable and port are working. If not replace them or try it on another computer. If they are working then the Calibrator Talk software may be configured wrong, have you contacted Barco? They have a troubleshooting area on the web site.
Mar 28, 2008 | Barco Personal Calibrator V 21 in.CRT...
Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black Logo
46 people viewed this question
Top Griffin Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Griffin Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
