Question about GPS
No voice prompts - Audio missing
Garmin StreetPilot c510 GPS Receiver
I have a Garmin StreetPilot c510 and on the "About" screen is shows:-
Audio Version: Missing
Obviously, there are no voice prompts! This was a secondhand unit when I bought it and I suspect this is why the vendor was selling. I did not get any CD or DVD with the unit, so no way of reloading this piece of software. I have tried updating the software from Garmin website, but still the same message. Can you tell me where I can download this bit of software, as I cannot find it to download on the Garmin site? Or could someone email it to me?
Thanks all,
Dave B.
  • 4 more comments
  • DaveBee Mar 13, 2008
    Problem now solved.
  • Anonymous Jun 15, 2008
    no voice
  • shmoeman Jun 28, 2008
    have a garmin nuvi 200w same thing i moved audio files off to do map update moved them back on after and now no voice prompts also says audio version missing
  • Anonymous Aug 20, 2008
    I had to download some updated info on my Garmin Street Pilot 2720 and since then the audio is missing. How can I fix this? This is not a second-hand unit--I bought it myself.
    Thank you,
  • madelaine131 Nov 18, 2008
    i made update for my gps and now audio is missing , my gps is mute , the volume button is high but my gps is without voice , i need help pls .btw , my gps is new , but in the box it was no cd or something else only the information books , no cd for drivers or something else,tx
  • azgroszmann Apr 24, 2009
    I have a garmin 7 and it lost the audio, how to get it back
the kowalski
  • 86 Answers
SOURCE: system software missing garmin 250w
If the unit indicates "software/firmware missing", then you can only try to re-install firmware by running WebUpdater again. If it doesn't work, then the unit has to be sent to service to have it re-flashed.
Posted on Jun 03, 2009
SOURCE: Garmin gps 45xl
To bring your Garmin 45 XL back to life ( reset ) hold down page and start untill the screen comes on. It will take up to twenty minutes to locate your available satelites..
Good luck
Vic
Posted on May 20, 2008
SOURCE: SISTEM SOFTWARE MISSING on my Garmin NUVI200 GPS
All Garmin users,
There is no easy solution for this except to return your unit to the nearest Garmin outlet. You need to have very special equipment called an E-Prom burner or writer which only Garmin have. With this equipment they re-programmed (restore) the operating system back on your specific Garmin unit and model.
The problem why anybody can't do it is because there is no way you can access your Garmin unit from a pc or mac if the operating system is lost or damage on your Garmin, for the simple reason your pc or mac can't reconize the device that is pluged in, because there are no communication platform between the two devices.
As simple as that, life with it or send your Garmin gps to an autherized professional Garmin dealer.
Marius Oosthuizen
Garmin dealer
South Africa
Posted on Mar 23, 2009
  • 6 Answers
SOURCE: Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
the kowalski
  • 86 Answers
SOURCE: I plugged the unit to my PC and went to the Garmin
If the software/firmware is missing, there was an error during the update of the firmware, most likely corrupt file(s) causing the unit to not being able to boot up properly.
You can try plugging it in to the computer again and re-install latest firmware version again. If your unit is unable to stay on during this process however, you'd probably need to send this unit in to service, as there isn't much else to do, as an end user.
Posted on Jun 14, 2009
Garmin c510 error message "No detailed maps found that support routing. The streetmap cannot be used without them" Don't have pin number! Solution?
You're unit is probably missing the gmapprom.img file (failed update maybe?).
Try contacting Garmin - if you've got registered maps they may send you another copy (although big file - 100+MB)
Aug 14, 2009 | Garmin StreetPilot c510 Deluxe GPS...
My Garmin gps is frozen on a screen telling me there are no maps found. I tried to reset it and put a memory card in it but nothing worked so far. Any ideas?
You're missing the file gmapprom.img on your C510 unit (possibly a failed update?).
Unless you have a backup it's contact Garmin I expect (maybe try getting a copy off someone but possible the file is locked to the unit as I have tried swapping SD cards containing maps in the past between units and no joy)..
Jun 04, 2009 | Garmin StreetPilot c510 Deluxe GPS...
No detailed maps found that support routing the streetpilot cannont be used without them garmin streetpilot c510
Jan 31, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Garmin c510 no maps
You're unit is probably missing the gmapprom.img file (due to the failed update maybe?).
Nov 19, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Unlock c510
Take the unit to where your nephew was playing with it, and it will automatically unlock. Otherwise, you'll need to send it in to Garmin with the receipt from an authorized dealer.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Portable GPS
All of the Garmin automotive GPS units that speak street names are also loaded with basic voice prompts. If one of these types of voice prompts has been selected, the voice prompts will not speak street names.
In order to change this setting on the StreetPilot c550/580, please follow these steps:
  1. In the Main Menu, tap on the Settings icon.
  2. Tap on "Locale"
  3. The second line on this screen has a picture of a mouth. To the right, the current voice for the GPS device is listed. Tap it to change the voice.
  4. Select a voice that is labeled with (TTS) at the end. These voices will speak street names.
  5. Select "OK". The voice has now been changed.
Your device should now speak street names.
Jun 10, 2008 | Garmin StreetPilot c550 GPS Receiver
Voice prompts disappeared!
It's possible that you just turned the volume all the way down. Otherwise just look into the system settings....
Mar 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't webupdate
sorry!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 22, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Voice Prompt
My husband had the same problem with his i2 Street Pilot.
He went to the Garmin web site and downloaded the latest
updated software version. You can then chose the language options, too.
Dec 31, 2007 | Garmin StreetPilot c310 GPS Receiver
GPS Logo
520 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
