Question about Whirlpool Washing Machines
Hello the front loader door is stuck and will not open. This has been this way all day Sunday. We have washed the clothes several times and it still will not open
  • 3,230 Answers
Well if you remove the 1/4" screws along the bottom most panel, the lower front panel will come down. If you reach up where the door switch is, on the bottom of the switch, there is a pull tab that will manually release the door. Please post comments if further you have the same problem.......
Good Luck!!
Thanks
Posted on Feb 01, 2010
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
Bosch error E23 flashing
disconnect the power the door unlock within 30 secound
Oct 12, 2014 | Bosch Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
I was washing a load of clothes and in the final spin the washing machine made a loud noice and then I saw a metal band in the machine with the cloths. But I can not open the door to find out what's...
Sounds like a front load washer ?. If it is, then there still maybe water in there which a sensor is detecting it thus keeping you from opening it even though you unplugged it then back in. It is a built in safety feature. Try pressing the stop button (unit plugged in) and holding it for several seconds. If that doesn't work, you need to call a tech. Last resort use a crow bar. Of course that will cause costly repairs. I am not a big fan of front loaders as there are too many problems with them and are harder to work on.
Good Luck
Dec 19, 2010 | Washing Machines
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a frigidaire front loader that I've owned for about 3 years. It traps water in the seal and also has mold growing inside it from time to time. It smells so badly right now that my entire wash room...
unfortunately we hvae created our own problems on front loads .all front loads all brands retain water in door boot .few people today wash with plain chlorine bleaches as result bacteria and mold are more likely to occur best solution wash door boot regularly with bleach and water solution run a bleach wash (no clothes) every few months and leave door open slightly after use don't give up too easily more than 1 cleaning may be necessary and should be done regularly
Apr 25, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
