The machine went through a cycle but now it wont empty the water out now?
  • Washing Mach... Master
  • 3,463 Answers
It is possibly a blockage of some kind, or the pump is not working for one reason or another.
As you do not state make of washer, it is impossible to advise you further.
Posted on Feb 01, 2010
Why wont my machine empty out..
The problem you are having is the pressure switch, also called the water level switch.Without a model # its hard to give any real direction for repair or any part #.
May 06, 2012 | Hotpoint Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Washer stopped and wont turn off
Unplug the appliance from power, or trip the circuit breaker and cut power to the appliance for about five minutes.
While appliance is unplugged check that the drain hose is not kinked and empty water from inside the machine.
Let me know if you still have the problem when you connect the appliance back.
If the appliance does not start back, then there is a faulty part, in that case give me the model number as printed on service tag and tell me when the appliance had been purchased, also tell me the country of purchase.
Many thanks.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Washing Mashine draw Wont Empty
check the screen on the valve where the hose connects to the washer, it may be clogged
Jul 07, 2009 | Washing Machines
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
