Question about Daewoo Washing Machines
My Daewoo dwf 185 mnp washing machine has got sticky black stuff in the pipes/machine.I supose it is as a result of soap or softener. How can I clean and with what
  • 16 Answers
SOURCE: my washing machine wont take the soap powder and softener
It could be a water inlet valve that is at fault. Are the hot and cold supplies turned on? Try opening the powder draw very slightly when the machine is filling with water, if no water in powder draw, chances are that the inlet valve is at fault, situated on the inside of machine where the filler pipes connect. Unplug machine from power supply before checking the inlet valves with a resistance meter, making sure to disconnect wires from one terminal to avoid false readings. Tom.
Posted on Mar 09, 2007
  • 30 Answers
SOURCE: Hotpoint WD64, leaking water from soap drawer
try turning down your cold water pressure. some times the pressure it is so great that the water hits the soap dispense and spill over. this is a common problem with front loaders??
Posted on Aug 15, 2007
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
masteria
  • 355 Answers
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
57 varieties
  • 1653 Answers
SOURCE: Fabric softener doesn't leave the dispenser
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
Eziset 750. Why is it leaving grease marks on clothes after wash?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
Mar 15, 2014 | Washing Machines
It leaves holes and looks like black rubber on it
the black rubber is most likely fabric softener build up. The hose are the marks of the bowl perforations. Once this black 'stuff' builds up from the over use of fabric softener it could mean the end of the machine. The way to try and get rid of it is to wash an empty load in hot water with Epsom salts. This will loosen the black grease but be careful as some loads further on, large amounts could release and mark you clothes. If the bowls can be removed from the machine they could be scrubbed clean but this is a costly exercise. Tip from now on do not ever use fabric softener. end of story. Use low sudsing soap in your washer whether it be a top or front loader. www.thewashingmachineman.webs.com good luck
Feb 23, 2011 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Water overflowing during use, the machine model is Daewoo airpower, bubble washing machine DWF 1150 P.
Seems like blockage in pressure system, machine will always think it is empty if so. Pressure system is under the lid, a round switch with a thin pipe going to it. At bottom of this pipe it is probably blocked with limescale or residue from detergent.
Feb 12, 2010 | Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
Good Luck!
Jun 16, 2009 | Washing Machines
Washing Machines Logo
150 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
