Question about Acer Aspire 5500 5570-2609 Laptop
I have acer aspire laptop. m experiencing so many problems one by one on it. first the adapter gave away. i replaced it with new one. Now the battery is dead. If i use the battery my lapto hangs.I use direct power now-a-days and the last but not the least i had a camera to this laptop which i could rotate 270deg. Now it doesnt work ta all:(
  • 27 Answers
If you are having lots of hardware problems, go to the dealer and demand him for a replacement.. regarding the battery, it is mandatory to use the ORIGINAL one for laptops..
Posted on Feb 01, 2010
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
My acer aspireone 150 not do anything. soon as i plug in the power , power light and battery led come up for 1 second and fade away .
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jul 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
My Acer Aspire one dosent charge completely to 100%, it stops at 87%. I have tried letting the battery run down completely, then starting a new charging process. formally it charges to 100%, then 3 days...
Hello.
From your description, your battery is losing its charge and needs to be replaced.
I'm experiencing charging problems with my own system and I noticed that the A/C adapter is very slightly frayed. So, check your A/C adapter as well and be certain that it is charging when you leave your system charging overnight. If you are still experiencing a problem, replace your battery.
Hope this helps.
Apr 02, 2011 | Acer Aspire One PC Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
I have an Acer ASpire 5741G I have the battery in but it is saying battery not detected and the fan isn't going either
I have the same laptop and the same problem. I solved the problem in 2 days.
ANSWER:: Shut down your computer, wait when your adapter
Aug 02, 2010 | Acer Aspire One PC Notebook
Acer aspire 4520g cannot start
I am assuming it does this even if it is plugged into power supply. Try removing the battery and then re-installing it. Maybe it has come loose or has a bad connection. When the power supply is hooked up does it show that the laptop is charging? Have you left the charger on there overnight? Maybe the battery is really weak. It sounds like a bad battery to me but the only way to know for sure is to buy a new battery or test it with another good battery and see if it does the same thing.
Sep 11, 2009 | Acer Aspire 4520-5582 Notebook
Battery ac adapter overheats
You need to ditch the battery on the laptop. It is causing the issue. This is a know problem with this laptop.
Mar 31, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
