Question about Sony Playstation 3 (PS3) Console
PS3 Communication Error with the server.this is a DNS error
My PS3 is telling me that it "succeeded" in obtaining my IP address,but now its telling me that an error occurred during communication with the server. This is a DNS error.(80710102ff), I Have tried every thing I now to do and it still doesn't work. When I run a connection test it comes up with,
Router connection -100%
Obtain IP Address- succeeded
Internet connection- failed
Playstation Rnetwork-
UPnP-
NAT Type-
This is really irritating frustrated that I can't go on line.
2 Suggested Answers
SpideRaY
  • 687 Answers
SOURCE: My PS3 is telling me that it
This sounds like you might need to open a port on your router or firewall to allow the PS3 to send info to the games specific server just because the PS3 has been given an IP address the PS3 still needs to connect through your router using NAT.
I suggest first turning off your Windows Firewall and your ISP firewall then into your router admin panel and open up the correct port then do the same on your firewalls.
Next, you need to enter these numbers for the PS3 to work.. so put these in the port start and end. 80 , 443 , 5223 , 10070 (start) and 10080 (end) , 3478 , 3479 , 3658 , 10070. They should be in both start and end except for the fourth which will have 10070 in start and 10080 in end.
The first 4 are TCP and the last 4 are UDP both types are required.
Posted on Feb 01, 2010
Tried connecting my ps3 with the wi fi . It obtains ip address successful but fails to connect to the internet . It says dns error 80710102.
Go to the PS3 Network Setup, choose "Manual".
Leave the option for DHCP under "automatic", and under DNS servers, manually add:
208.67.222.222 or/and
208.67.220.220
These are the IP addresses for the Open DNS project and now your PS3 will be able to resolve internet addresses.
Mar 08, 2011 | Computers & Internet
My PS3 is telling me that it "succeeded" in obtaining my IP adress,but now its telling me that an error occured during communication with the server. This is a DNS error.(80710102ff), I Have tryed every...
Feb 01, 2010 | Sony Playstation 3 (PS3) Console
Dns error
First chek your cables to make sure they're tight. Then test the internet connection in the settings. Restart ps3 and it should restore internet connection. If not, Cable is not working or is damaged.
Aug 12, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Heeeellllllpppppp!
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Ps3
Can you give a little more information about your configuration? Are you connected at all? Do you know what is going on? Does your car have an automatic transmission? Do you have people hooked to the underground chopshop network? Have you relocated through a time portal? If you have, did you tell sony the problems people are having in the future with there PS3s? Did they commit you into an asylum? Did you call sonys tech support hotline? The number is 1-800-345-7669. I hope they can help you without having to unanswer your questions with more questions like these. If they don't know, I would suggest smashing it with a hammer.
Feb 01, 2008 | Sony Playstation 3 (PS3) Console
Hi, i had the same problem but it was fixed by simply re directing my ISP's DNS settings away from Sony's. manually change your DNS settings to the ones below and it should work fine !
  • 208.67.222.222
  • 208.67.220.220
  • Nov 23, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    311 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
