Question about Dewalt D25330K 2KG Sds Plus Demolition Hammer 240V
Hammer action does not work, the Kango only works in rotation mode. I have stripped the gearbox down and cannot find any obvious problem. Not sure what the mode selector knob is supposed to do as it only seems to move a sleeve back and forward along the main drive shaft without actually contacting anything. Regards, Terry.
  • sargo Feb 01, 2010
    Forgot to mention it is a Kango 426 800W model.
If you don't get it working I will buy it not working and stripped. let me know ( kango 426)
swtoyogist2@aol.com
lee
Posted on Feb 13, 2010
How to fix Hammer drill which does not "hammer" in Hammer mode, but rotates normally in rotary but NO hammer action in this mode also?
then the broken hammerpiston or the impact bolt ring in front of the locking sleeve can be broken
Oct 22, 2015 | Rotary Drills
Hammeraction cuts out
when hammering there is only medium pressure on the unit
you let the unit do the chiselling as any pressure and the unit cannot work as it requires for it to be allowed to rebound a it
Nov 17, 2017 | Metabo Drills
Drill bit rotation stops
www.powertools-aftersalesservice.com this site allows you to input the model number in the trade name box or if you look on your tool you will see a 10 character code quite often starting with a '0' enter this number in the part number box. This will then display your exact model variation, voltage etc. (the former search will bring up a list of possible models, voltages and countries). From the parts break down you will see there is a clutch fitted. Testing of clutches is not easy and many makes can not be adjusted. I have seen on SDS drills the guide lugs in the tool holder have sheared/Worn away and the drill bit can be turned freely if the steel balls are removed from the chuck. On a max there are more lugs but I don't suppose it is unheard of these al wearing away. If it is a clutch problem you will hear the drive slipping. If it is the latter the drill will sound normal. All that said It could even be gear teeth that have broken and so not meshing in the rotation mode. Only stripping the tool will identify the fault.
Mar 01, 2014 | Bosch 11264EVS 158 SDSMax Combination...
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
Hammer action is very weak for kango 900 demolition hammer
Check the brushes. If that doesn't work, try cleaning and re-lubricating. Your local tool rental company may be able to either service it or send it to someone who can (for a fee of course).
Jun 13, 2011 | Hammering
I cant find kango oil for my kango electric hammer
What kango hammer do you have? I am most familiar with the UK kango 900 and 950, pre-milwaukee.
Sep 18, 2010 | Hammering
Demolition tool or breaker
The shaft from the motor to the drive gear is likely not working the action of the hammer. There is a gear which spins the gears to achieve the hammer action, suspect the gear is either stripped, broken or both.
Jan 17, 2010 | Dewalt D25330K 2KG Sds Plus Demolition...
Kango 900 demo hammer on off switch needs replacement were can i purchase parts.
what country are you in? in australia atlas copco are the distrbutors. i`m sure you can find out on the internet
Aug 11, 2009 | Hammering
My jackhammer seems weaker than what it should be. it runs and functions, but doesn't sound as loud as it should, nor have the power it should.
if pneumatic, it needs to be oiled with some air tool oil into the air supply nipple, 4 drops a day when used
Aug 08, 2009 | Hammering
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Dewalt D25330K 2KG Sds Plus Demolition Hammer 240V Logo
971 people viewed this question
Top Dewalt Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
richie46
Are you a Dewalt Hammering Expert? Answer questions, earn points and help others
